uldis
v6.29 will be released this week!
Tue May 19, 2015 2:04 pm
We have plans to release v6.29 during this week.
Please check the latest rc version (v6.29)
http://www.mikrotik.com/download#rc
For those that had confirmed bug reports, please check if the issue is resolved.
What's new in 6.29rc22 (2015-May-19 13:38):
*) fasttrack - correctly close fasttrack connections;
*) firewall - fixed sector writes rising starting since 6.28;
*) tile - fixed fasttrack;
*) snmp - fix rare bug when some OIDs where skipped;
*) ssh - added aes-ctr cipher support;
*) mesh - fixed kernel crash;
*) ipv4 fasttrack fastpath - accelerates connection tracking and nat for marked
connections (more than 5x performance improvement compared to regular slow
path conntrack/nat) - currently limited to TCP/UDP only;
*) added ~fasttrack-connection~ firewall action in filter/mangle tables for marking
connections as fasttrack;
*) added fastpath support for bridge interfaces - packets received and transmitted
on bridge interface can go fastpath (previously only bridge forwarded packets
could go fastpath);
*) packets now can go half-fastpath - if input interface supports fastpath and
packet gets forwarded in fastpath but output interface does not support fastpath
or has interface queue other than only-hw-queue packet gets converted
to slow path only at the dst interface transmit time;
*) trafflow: add natted addrs/ports to ipv4 flow info;
*) queue tree: some queues would stop working after some configuration changes;
*) tilegx: enable autoneg for sfp ports in netinstall;
*) health - fix voltage on some RB4xx;
*) romon - fix 100% CPU usage;
*) romon - moved under tools menu in console;
*) email - store hostname for consistency;
*) vrrp - do not reset interface when no interesting config changes;
*) async - fixed ppp server;
*) sstp - fixed router lockup;
*) queue tree: some queues would stop working after some configuration changes.
*) console - allow '-' characters in unknown command argument names;
*) fixed CRS226 10G ports could lose link (introduced in 6.28);
*) fixed FREAK vulnerability in SSL & TLS;
*) ipsec - allow to specify custom IP address for my_id parameter;
G2Dolphin
Re: v6.29 will be released this week!
Tue May 19, 2015 3:58 pm
Great news! I really waiting that release... after buggy 6.28. :)
CCR1009-7G-1C-1S+PC, RB3011UiAS-IN (2011 case+3011-RM), hAP ac, mAP2n/mAP2nD, wAP ac LTE6
There's nothing wrong with your Internet connection, I have a broken avatar. :)
jarda
Tue May 19, 2015 4:18 pm
Is the sstp/l2tp problem with client's addresses going into DI state solved in this version?
105547111
Tue May 19, 2015 6:13 pm
Been running the 6.29 rc versions once I found the massive sector re-writes. No issues since rc20
Petzl
Tue May 19, 2015 7:46 pm
I did some upgrades on RB493AH from 6.12 to 6.29cr13 to test ROMON
With 6.29 it seems that the ethernet ports sometimes go down and up.
uldis
Tue May 19, 2015 7:51 pm
Please upgrade your router to v6.29rc22 and check again if the issue is still present.
ffernandes
Tue May 19, 2015 10:03 pm
rates in simple queue don't work with fastpah? i'm seeing clients get more speed from what queue is limiting...
just me ??
honzam
Tue May 19, 2015 11:09 pm
Ticket#2014021866000279 - Not fixed from 24.2.2014
Ticket#2015041666000428 - No answers from support from 21.4.2015
LAN, FTTx, Wireless. ISP operator
paoloaga
Wed May 20, 2015 1:04 am
This bug has been fixed twice :wink:
LynxChaus
Wed May 20, 2015 1:07 am
Auto-negotiation broken on CCR ethernet - ports only work in 10Mbit/Half mode.
IntrusDave
Wed May 20, 2015 1:48 am
You may need more detail. Each of my CCR's (Nine CCR1009-8G-1S-1S+ and four CCR1016-12G) are all auto-neg and all linked at 1Gbps with no issue.
David Joyce
Network & Security Engineer
Intrus Technologies, LLC.
Rancho Cucamonga, CA, USA
Neilson
Wed May 20, 2015 2:34 am
just me ??
Is the queue showing the larger amount of traffic? or a limited amount? or none?
Fast Path / Track is deliberately bypassing parts of the processing, the idea is to move the packets wholly inside the kernel to output interface.
Was it working before?
Regards
Alexander
105547111
Wed May 20, 2015 4:05 am
My CCR1016-12G its purring like a kitten....
bajodel
Long time Member
Long time Member
Wed May 20, 2015 8:43 am
Input traffic on bridge interfaces is still not counted in 6.29rc22 (now even graphs show only output traffic on those interfaces obiovsly).
105547111
Wed May 20, 2015 8:48 am
This is from the actual fasttrack thread....
Re: FastTrack - New feature in 6.29
by becs » Wed Apr 29, 2015 9:07 pm
In current implementation (6.29rc15) FastTracked (and FastPathed) packets will not be accounted in Traffic Flow.
But.. there are possibilities to extend FastPath/FastTrack feature set in the future.
At the moment, please, test basic FastTrack functionality, and report back if you encounter any issues.
___
So from this I'm assuming its still not counted...
bajodel
Long time Member
Long time Member
Wed May 20, 2015 9:13 am
___
Thanks 105547111 for hints, I'm not using fasttrack now ..and fast path on bridges was already there from ages. So something have been changed/updated on fast path implementation so that .. .. bla bla .. :D
strods
Wed May 20, 2015 10:18 am
ffernandes, Neilson - If you are using bridge but use-ip-firewall is not enabled, then Queues will not be limiting bridged traffic:
http://wiki.mikrotik.com/wiki/Manual:Interface/Bridge
http://wiki.mikrotik.com/wiki/Manual:Packet_Flow_v6
paoloaga - These were two separate fixes where issues were triggered in different ways
LynxChaus, Petzl - Please write to support@mikrotik.com. It must be something specific with your configuration/topology. Send supout files and we will inspect them
105547111 - Please als owrite to support@mikrotik.com. Did it start with upgrade?
bajodel - Where it is not counted? Have you checked your bridge settings?
LynxChaus
Wed May 20, 2015 11:26 am
CCR1036-8G-2S+ - can't negotiate 100-Fdx speed.
name="ether7" default-name="ether7" mtu=1500 l2mtu=1580 mac-address=XX:XX:XX:XX:XX:28 orig-mac-address=XX:XX:XX:XX:XX:28 arp=enabled auto-negotiation=yes advertise=10M-full,100M-full,1000M-full full-duplex=yes tx-flow-control=auto rx-flow-control=auto speed=10Mbps master-port=none bandwidth=unlimited/unlimited
Note "speed=10Mbps" - remote partner D-Link (mgmt interface 100-FDx). And interface RX packets only if it manually configured to 10Mbit speed.
DjM
Wed May 20, 2015 12:03 pm
Hello MikroTik support team,
is bug below fixed, please?
Ticket#2015032266000169 Unable to set comment on dhcp-server alert via CLI
Thank you
ffernandes
Wed May 20, 2015 12:36 pm
strods... i'm not using bridge ....
normal routing with some simple queues
strods
Wed May 20, 2015 1:02 pm
ffernandes - Please write to support@mikrotik.com and attach supout file. We will check that for you. Sounds like multiple queues are being used for same traffic or something like that.
ffernandes
Wed May 20, 2015 1:42 pm
mail sent :)
TomosRider
Wed May 20, 2015 2:44 pm
Please fix issue with loosing static DHCP leases after reboot.....
skibi82
Wed May 20, 2015 4:11 pm
When the problem is solved by mikrotik support?
Ticket#2015042166000534
cegner
Wed May 20, 2015 4:12 pm
What about #2015042966000618?
bajodel
Long time Member
Long time Member
Wed May 20, 2015 5:40 pm
Absolutlely sure my bridges are ok (they where ok till 6.27 ..probably 6.28 also but not sure)
See http://forum.mikrotik.com/viewtopic.php ... 89#p482184 for a screenshot.
I've noticed that when my bridge interfaces graphs become "unidirectional" (only output traffic and no input)
apteixeira
Trainer
Trainer
Thu May 21, 2015 3:02 am
There is a bug on BGP VPLS tunnel. I made a post here:
http://forum.mikrotik.com/viewtopic.php ... 05#p482914
Best regards.
KennyPowers
Thu May 21, 2015 11:26 am
Was the LAN - WAN throughput issue fixed I found about a 40% decrease in speed on a 250MB connection vs 6.15 which always offered the full 250MB. This was all tested with default config.
uldis
Thu May 21, 2015 5:16 pm
Have you reported this problem to support@mikrotik.com ?
uldis
Thu May 21, 2015 5:19 pm
Have you reported this problem to support@mikrotik.com so we could try to reproduce it?
uldis
Thu May 21, 2015 5:20 pm
This bug is not fixed yet, still in process. Most likely will be fixed in RouterOS v6.30.
uldis
Thu May 21, 2015 5:21 pm
We can't fix that problem because you haven't provided us support output file with the configuration. If the configuration is too sensitive, please tell us step by step how to reproduce this issue locally.
honzam
Thu May 21, 2015 5:22 pm
And my post?
uldis
Thu May 21, 2015 5:24 pm
Best regards.
We have reported this bug and we will try to fix it but the fi might be only in RouterOS v6.30.
ufm
Thu May 21, 2015 7:33 pm
Wow! Support says time.
Maybe I'm also lucky?
Dear Mikrotik support, what about
2014122166000217
2015050866000629
and
2015041166000124
Elfos
Fri May 22, 2015 1:48 pm
What about the issue described in 2015042066000634?
Until version 6.29rc22 the problem persists !!!
ufm
Fri May 22, 2015 2:33 pm
2014122166000217
2015050866000629
and
2015041166000124
No, it seems. Everything is as usual.
uldis
Fri May 22, 2015 4:02 pm
After receiving all your feedback we are planning to fix those main issues and we plan for v6.29 release in the middle of next week.
If you discover any new problem please post it here and report to support@mikrotik.com
honzam
Fri May 22, 2015 4:41 pm
Thanks for info
ufm
Fri May 22, 2015 5:42 pm
I think many will support me - we are ready to wait two or three weeks (or even four weeks :). But let it be a real bug fix release.
Thanx!
vortex
Fri May 22, 2015 7:56 pm
Waiting for the security fixes.
Just no stuff which worked in 6.27 broken, and no new holes introduced is enough.
No need to hold for too long.
I guess RouterOS needs a Maintenance stream and a Feature stream, like the later versions of IRIX had.
avenn
Fri May 22, 2015 10:21 pm
Thanx!
+1000 No need to rush for rushings sake!
MTCRE - MTCNA - MTCTCE
dimi
Fri May 22, 2015 11:55 pm
blah-blah-blah again Mikrotik(((
katit
Sat May 23, 2015 7:34 am
Ok, I guess simple fix and I guess this will be a problem for many newbies who uses auto-config. If I change base IP and range and click "Apply" in Auto-config - almost everything was great except that DHCP server setup DNS name server stayed .88.1 and of course "no internet".
Abdock
Sun May 24, 2015 5:24 pm
+1 We need a stable release, then just patch up. As we cannot keep up with these patches, and making list of what works with one and what breaks with other. At the end will just have to stop upgrading, and stay with different version for different tasks.
deanMKD1
Sun May 24, 2015 11:58 pm
Mikrotik please dont produce untested and buggy builds ! Work on it, one month more, but give us stable and bug less build.
Lupin
Mon May 25, 2015 10:08 am
Any improvments or Bug-Fix on Wireless section?
For example:
- Tx-Power not shown in 802.11ac
- Scan to a File: save on the file the results obtained with timed scan instruments like "Scan", "Freq.Usage", "Snooper", "Spectral Scan", "Spectral History"
normis
Mon May 25, 2015 10:18 am
For example:
these are not bugs, but feature requests, we are still aware of them, but nothing has changed in 6.29
ibm
Mon May 25, 2015 11:10 am
For example:
The min-tx-power that in Netbox and Netmetal can't be set below 6db will be fixed?
kez
Tue May 26, 2015 11:39 pm
Talking about new features, I would like to see new settings for netwatch. For example: numbers of pings, delay between them, delayed start.
I guess the first one should not be so hard to add :)
I've got few unstable links here... :shock:
jarda
Wed May 27, 2015 7:48 am
It was already requested. Why you didn't join the original request thread?
grusu
Wed May 27, 2015 4:56 pm
6.29 version seems to be ready:
http://demo.mt.lv/
bajodel
Long time Member
Long time Member
Wed May 27, 2015 6:34 pm
http://demo.mt.lv/
and in download page (RouterOS v6.x release candidate) >> http://www.mikrotik.com/download
105547111
Wed May 27, 2015 9:21 pm
If you look today at the RouterOS v6.x release candidate, 6.29 final is released. Its not showing up yet on the normal download channel, but the final version is posted there :)
ddejager
Wed May 27, 2015 9:47 pm
The current list of fixes in the changelog for 6.29 no longer lists
Is this fix still present, even though it is not listed?
tmp
Wed May 27, 2015 9:53 pm
Thanks to 105547111 for the information.
I do also hope that the "sector writes-Bug" is fixed in this release. I upgraded hap lite a second ago and will monitor my sector counts.
tmp
Wed May 27, 2015 10:14 pm
It does not seem to be fixed.
noyo
Wed May 27, 2015 10:31 pm
after upgrade from 6.29.rc22 to 6.29
bajodel
Long time Member
Long time Member
Thu May 28, 2015 1:34 am
I noted that in logs from first 6.29rcxx .. (maybe I'm wrong but even in 6.28 ..)
bajodel
Long time Member
Long time Member
Thu May 28, 2015 1:50 am
Anyway ..even on final(?) 6.29 on bridge interface (at least on bridge with only 1 ethernet interface) the input traffic counters dosen't work (output counters are ok). Verified on RB2011, CRS125, RB433.
If I disable Fast Path on bridge settings, input counters of bridges start again ..and viceversa.
jarda
Thu May 28, 2015 6:51 am
Did you noticed official release announcement? Maybe it is not final yet, but some new way how mikrotik tests their products.... Don't you think?
Masyanich
Thu May 28, 2015 8:50 am
when you can I upgrade through the " packages-update"? Does the final version have a IGMP-proxy?
nkourtzis
Thu May 28, 2015 10:17 am
WOW!!!
Yesterday I set up a RB951G for a client. I put v6.29 on it, set up NAT, fasttrack, a couple of L7 filter rules, overclocked the CPU to 750 MHz (it is rock stable there) and did a few speedtests with a gigabit upstream. Let me tell you, nothing could have prepared me for what I saw! 750+ Mbps up/down! NATted! CPU was at 55 - 65%, which probably means that I hit the actual limit of the line. Without fasttrack, I saw around 200 Mbps with CPU at 95%.
Well done on this front, Mikrotik!
Passionate about networks
Enthusiastic about Mikrotik
MTCNA | MTCRE | MTCINE
No trees were killed to send this message,
but a large number of electrons were terribly inconvenienced.
th0massin0
Thu May 28, 2015 10:35 am
Seems to be fixed in today's 6.29, tested on RB2011UiAS
Elfos
Thu May 28, 2015 3:01 pm
Referring to Ticket # 2015042066000634, the problem persists.
My Radius is configured to allow one connection per customer.
I do not believe that is the Radius, because what happens is as follows:
My Radius only authorizes the connection.
The IPS POOL is in Mikrotik
1. Customer initiates PPPoE dial;
2. Mikrotik queries Radius;
3. Radius authorizes the client;
4. Mikrotik authenticates the client.
THE PROBLEM:
1. Randomly some authenticate clients, but do not sail;
2. Active PPP connections in the address field, appears in the IP that the client received;
3. PPP interface, the same client, the Remote Address field is empty;
4. PPP interface, this same customer is om the only status with D (dinamic) but nowhere with R (Running);
5. In IP Address, the same client is in red, with the status D (Dynamic) and I (Invalid);
6. Interfaces, the same customer is with Status D (Dynamic) and without the R (Running) and also not as a slave of the physical interface;
7. IP Route, is not created proper route (/ 32) to the client.
RESULT: The PPPoE session is established, the client receives IP, but the RouterOS for some reason creates totally bugged connection.
CUSTOMER IS NO CONNECTION.
After some time, the RouterOS "adjusts" the connection, creates the route and the customer browsing normally.
jarda
Thu May 28, 2015 3:24 pm
As there is already 6.29 thread, this one should be closed to prevent doubling the posts.
Users browsing this forum: johnny09, sindy and 95 guests
