ghoelzl
CAPsMAN v2 “Client To Client Forwarding"
Tue May 19, 2015 5:11 pm
CAPsMAN v2 allows configuration of "Client To Client Forwarding" within one AP (via “Datapaths" or “Access List”). For solving some security issues we want to disable "Client To Client Forwarding" for the whole wireless network. The APs work in the "Manager Forwarding Mode” and are connected to the CAPsMAN v2 through dynamic interfaces.
Is there an easy option to disable "Client To Client Forwarding” between clients on different APs as well?
pukkita
Trainer
Trainer
Re: CAPsMAN v2 “Client To Client Forwarding"
Tue May 19, 2015 5:17 pm
set all ports of the bridge where all APs are with same horizon value.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
ghoelzl
Tue May 19, 2015 6:13 pm
Great! Many thanks to pukkita for the quick solution!
Set "Bridge Horizon" under "CAPsMAN-Datapaths" unequal to zero and all the APs reconnected immediately with the new value. Works like a charm...
Users browsing this forum: marekm and 67 guests
