What antenna and what radio card?I have a problem that hopefully someone out there can give me some advice on... this is not directly related to the mikrotik OS or the routerboards, but the problem did not exist prior to using them, so i thought I would ask here and see if anyone else has come across this...
I'm back to using the Superpass 2.4 8dB Omnis. Only had two problems in four years of use with fifty in the field, price is very reasonable and they deliver the gain they advertise. Don't know why the PacWireless cause problems, but they do. Pity, the mounting hardware is great.Yes most of them are pacWireless, 3 of them were older YDI antennas, that had been deployed for 1-2 years already without any problems, but they did not blow near as often as the pacwireless.
What brand/model of antenna did you switch to? I am willing to try another, although i am a little gunshy...
Please tell us how some pictures schematic can you??I all. we are having the same problem her in Sweden...
but . we rebuilt the antennas with better grounding, that helps some times. and i reparing the radiocards by removing the Diversity switch in the cards. then the cards working perfect again Smile so pleas do not throw the cards in the trasch cans!.
Yes titius, we know there is a lot of better antennas, but what about us who bought 30 pieces of those antennas? Replacament with other antennas, which don't cover full 360 degs is not a solution. Pacific Wireless should fix this.And about the static problem I HATE PacWireless Omni ants, I switched to homemade 17db waveguide and AMOS ANTENNA
web site is on Serbian language but you'll get around and there is some english links to sites and people who tried to make this great antenna for few bucks.
if that antenna is not omni ... 360 ... then send them back to ... netiks ?:)Yes titius, we know there is a lot of better antennas, but what about us who bought 30 pieces of those antennas? Replacament with other antennas, which don't cover full 360 degs is not a solution. Pacific Wireless should fix this.
Talked with them just a few minutes ago.. seems there is a defect in the mfg of the antenna, and I was told to RMA them. So if anyone else is experiencing this, you might contact pacwireless, or your distributer regarding this. He told me they were going to rework the product and wasn't sure when they would have the replacement product out.
this only applies to the OD24-12 Omni 12DBi Antenna.
please give me a photos here, i want to see how you fix this problem.yes, very often problem with Omni antennas, because, as I understood, they collect statical electricity, until radio gets blown. I've got card blowned almost every week.
I also thought that there is no solution for this problem, but in fact solution was quite simple. I took few meters of cord (wide one): then I wrapped one end around the connector on the antenna (on the place where cable connects to antenna), and another end to lightning rod. So far (5 months) there was not single problem.
I'll try to post some pictures when I'll go on the roof
mmm i have lost 3 radios, and use the antenna od24-12, in 2 monthsI don't know about the law suit, because i use Trendnet TW-503PI, and it was always replaced under warranty, although reseller was suspicios what are we doing to those cards
So, anyway: Pacific Wireless should be informed about this problem, because it's a MAJOR problem, not some minor bug. There are "tweaks" how to prevent this, but anyway, this shouldn't happen.
Gerard, did you try it without the "pom,pom" on top and did it not work? or just wanted to overkill it right off the bat and not have to worry about it?
Did the copper wire seem to hurt the signal levels any?
is a very good notice, one week ago, in the roof in a house, a Tranzeo radio, put everything, but no finished) , put Tranzeo Tr-6600, omni 12 dBi hyperlink, and lightning arrestor, but no finished, no grounded.Well, as an update, I did just as mwi and gerard suggested, and have now been up for more than 30 days on that tower! for that tower.. that is a record! I did not put the pom pom on mine, but if it looks to be needed in the future I will.
Thanks for all your advice!
also thanks for the pics on the card fix, ill give it a try as time permits...
thanks very much for you very fast reply, very nice solution, really i want see you pictures.My appologies, this reply was more for those helping that were familiar with what i was going to try (read several of my previous posts)
I put a piece of number 8 wire up the side of the antenna and about six inches above the top. and secured it to the side of the antenna all the way down to the surge arrestor (i have used the polyphaser as well with the same results FYI) and secured it to the same ground that the rest of the equipment is using.
If i get back up there I will get some pictures.
I am located primarily in Kansas, USA. We are plagued with lots of wind here, and after talking to several people here, and then several radio engineers (some specializing in antennas and design) As i understand it the wind causes static buildup on the antennas, and eventually causes the problem. which would make sense because the problem has happened after just a very windy day with no clouds. I am no expert on the subject, but before in the same position with the same antenna. I would lose a card a week (on a good week) now i have gone 30+ days without a problem, just by adding a piece of copper wire up the side of the antenna.
What i meant by no pom,pom was that I used just a piece of wire without the pompom at the end.
sorry for the confusion.
In a windy spot.My appologies, this reply was more for those helping that were familiar with what i was going to try (read several of my previous posts)
Think the method of wiring the Rx and Tx straight will only work for the cards if you plan them to use for N-stream/ only Tx or Rx mode.
for normal use of only one antenna connector you HAVE to use the diversity switch i believe, and were to get those ?
numbers on the chip are 512 / 3011 / 21, no brand or anything else.
can someone confirm that only diversitychip is broken ?, and the card has its original receive sensivity on the Rx port when wired straight ?
Connect Pins
TX to A1
RX to A2
The TX & RX pins are the ones closest to the ufl Connectors.
Diversity switch disabled!
This is now the beginning of December. Is this stil working for you. We have a similar problem in South Africa. We are about 3000 feet above sea level with a lot of lightning and thunder, also dry weather. We are loosing cm9 and rb52 on cpe's (using wrap board with either radios, 5.8 ghz). About 20 clients for about 2 months, lost about 10 radios so far, mostly in electric storms or some on windy days. I have one client that I loose after each storm, he is on a 36 feet metal pole (with grounding rod) -- see pic. We know the problem is caused by static electricity. We were first using a all plastic enclosure and replace it with a unit that has a metal backplate we we experise the same problem. I am going to replace the radio again today including the copper rod you suggest to see if this will solve our problem.My appologies, this reply was more for those helping that were familiar with what i was going to try (read several of my previous posts)
In that thread you talk about packet loss or interference or whatever ... it's really not clear what your problem is other than you seem to have one. This is most certainly not related to the issue discussed here.The problem is atheros chip set . see :
http://forum.mikrotik.com//viewtopic.php?p=60412
We ran a small wire from the top of the omni (no pom pom) to the bottom part of the omni,
to the ground of the mini pci or to the RB532 boardthen to the radio
nickb, consider yourself very lucky! I was one too that has had this ESD problem. And I use gas-discharge surge protectors on EVERY radio on EVERY tower. I cannot recall just how many cm9's I had went through in a month from ESD. Since I added the copper wire to the side of the Omni my troubles have totaly gone away. It sounds crazy that this idea would even work, but it did fix of patch the problem. Best bare piece of copper I ever purchased! And I think it has helped others as well.We use gas-discharge surge protectors on EVERY radio on EVERY tower. I have probably 4 or 5 pac-wireless 12dBi omnis in the field, and a few other brands. We've never lost a radio to this issue.
Could you tell me if you have also notice some difference in terms of signal client, latency, ping time? I want understand if a problem that I have from long time is related a not ground issue + ESD problem.Since I added the copper wire to the side of the Omni my troubles have totaly gone away
Yes, I'm glad we have not had this problem. Honestly I think that it depends heavily on the climate of where the equipment is located. i.e. humidity, temperature, types of storms, wind patterns, and things of this nature. When I first heard about this issue several months ago, I became very nervious and started watching closely. However, nothing has happened (or had happened before) of this nature. I find it odd, considering that we are in the midwest, and have lots of wind and some pretty heavy duty thunderstorms.nickb, consider yourself very lucky! I was one too that has had this ESD problem. And I use gas-discharge surge protectors on EVERY radio on EVERY tower. I cannot recall just how many cm9's I had went through in a month from ESD. Since I added the copper wire to the side of the Omni my troubles have totaly gone away. It sounds crazy that this idea would even work, but it did fix of patch the problem. Best bare piece of copper I ever purchased! And I think it has helped others as well.
Dude,You are my hero!
That is exactly what i am going to try too, fairly soon.
mwi, suggested teh same to me, and I havent had a chance to implement it yet, i had already cahnged all but one tower to two 180 sector antennas, which i didnt want to do, but it was the only thing working. the one tower i have left with an omni is hurting right now, but only has one cusotmer on it and they live underneath the tower. thier signal sits at about -80 but they are on.. so i am going to try this out on it, and if all goes well. I will report back here.
Do you have power regulator?This is now the beginning of December. Is this stil working for you. We have a similar problem in South Africa. We are about 3000 feet above sea level with a lot of lightning and thunder, also dry weather. We are loosing cm9 and rb52 on cpe's (using wrap board with either radios, 5.8 ghz). About 20 clients for about 2 months, lost about 10 radios so far, mostly in electric storms or some on windy days. I have one client that I loose after each storm, he is on a 36 feet metal pole (with grounding rod) -- see pic. We know the problem is caused by static electricity. We were first using a all plastic enclosure and replace it with a unit that has a metal backplate we we experise the same problem. I am going to replace the radio again today including the copper rod you suggest to see if this will solve our problem.
I am happy to see other's have the same problem and that somehow we should get around this problem. We will be getting Roo enclosures that we are importing from the states and we hope this will help us overcome our problems.
Your comments. (not sure how to add a image? first time posting!)
Alright Gerard, Thats what i will do thenI don't do anything special for my 900mhz omni's and I haven't lost any cards yet..
-Gerard
See above thread from Krunoslav....yes, very often problem with Omni antennas, because, as I understood, they collect statical electricity, until radio gets blown. I've got card blowned almost every week.
I did the same, No pom pom just a ground rod about 5 inches above it. been running strong for 3 months... -JordanI ran a ground without pom pom, just 3 inches above the top, on my 2.4GHz omni as well as my 900MHz. Cheap insurance.
may i want use sepearte earthing wire for all things or same ground is enoughUse :
- DC Grounded Omni
- Use Ethernet surge protector
- Ground your :
- board
- enclosure
- antenna mounting
- etc.
Thx
//Budi
