If you had a 10Gb/s link between 2 CCR's and you wanted to encrypt the link what tunnel/encryption would you use and what speed do you lose due to the tunnel/encryption? Is it possible with CCR's to encrypt that link?
While I do lots of encrypted tunnels with microtik I have never wanted to take a 10Gb/s link and encrypt the link, ie all traffic goes down the encrypted tunnel from 1 data centre to another.
So my question relates to the performance of the encrypted link and what over head there is, what bandwidth do we lose by encrypting the link.
There is no point encrypting a 10Gb/s link if I can then only send 2Gb/s data down it due to overhead.
Does anyone have any stats on the most efficient encrypted tunnel with 2 x CCR's on 10Gb/s.
Anyone got a lab with 2 x CCR's
Tony
