jmginer
BGP filter based in address-list?
Thu Jun 11, 2015 7:16 pm
I have a address-list with my country IPs (based on this http://blog.erben.sk/2014/02/06/country-cidr-ip-ranges/)
I have 2 BGP upstreams.
I want use one of the upstreams for users from my country and the other upstream for international visitors.
It's possible?
Thanks!
patrick7
Re: BGP filter based in address-list?
Thu Jun 11, 2015 11:24 pm
You could try (maybe with a script) to add the prefixes to a routing filter.
jmginer
Fri Jun 12, 2015 12:26 am
Or filter by AS?
I have a list of all AS numbers of my country.
Can you let me to know a example of a filter?
Thanks!
nz_monkey
Fri Jun 12, 2015 11:48 am
In Version 7 we should be able to do this.
And also have "Add to Address List" as a filter option.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
jmginer
Fri Jun 12, 2015 12:03 pm
I have 2 peers (Peer1 and Peer2)
I've do this to force the incoming connection from AS22222 route via the Peer2.
/routing filter
add action=accept chain=Peer1-IN prefix=0.0.0.0/0
add action=discard chain=Peer1-OUT bgp-as-path=22222
add action=accept chain=Peer1-OUT prefix=1.2.3.0/24
add action=accept chain=Peer2-IN prefix=0.0.0.0/0
add action=accept chain=Peer2-OUT prefix=1.2.3.0/24
add action=discard chain=Peer2-OUT
But not run...
The AS22222 is my Internet connection and when I trace the network 1.2.3.0/24 I'm still routed via the Peer1 :(
Any idea?
Thanks!!
Users browsing this forum: No registered users and 11 guests
