ismets
Which wireless product?
Mon Jun 15, 2015 8:17 pm
Hi
I need 1 AP and 2 CPE point-to-multi or 2 AP and 2 CPE point-to-point
CPE 2.5km and 1km.
I need more than 100MB.10 camera and and data.
So cold -40 C. Snow and ice.
Which device for me?
rocknight13
Re: Which wireless product?
Mon Jun 15, 2015 8:46 pm
Dear ismets,
I am not sure about your needs. but I think you asking for 1AP with 2CPE as PtmP or 2 links as 2 AP and 2 CPE as PtP.
I suggestion for you QRT 5 or QRT 2 as PtP connection these are very useful for your needs I get more than 100MB upload and download throughput with these points at more than 5Km as shown below
But if you like to make it as PtmP you can use NetMetal 5 with suitable sector which can cover your both CPE angle you can find a lot option but be sure to get one support ac band
and for 2 client side you can use SXT 5 ac
hope this can help you
ismets
Mon Jun 15, 2015 9:18 pm
Hi Rocknight
I like SEXTANT G 5HPnD.
2 PtoP set.
How is running temprature.-30,-40 C.Is it waterproof.
ismets
Mon Jun 15, 2015 9:48 pm
Hi
SXT SA5 ac is verry good.
I think buy this.
Have you had any problems in this product
Thanks.
rocknight13
Mon Jun 15, 2015 10:38 pm
I am not recommended SXT SA5 ac it came with sector antenna with wide angle that means it is not stable for PtP in 2.5KM. you can use it as AP PtmP but even for that 13dbi is not good for such distance.
I recommended for you new QRT 5 ac or DynaDish 5 they are perfect for high band application.
most of these out door units are working perfectly in -30C to +70C and build based on IP67 or IP66 which is completely waterproof you can see the details about IP66 and IP67 in link below
http://www.oldhamgas.com/en/blog-ip66-ip67
and you can get full details for :-
QRT 5 ac -------http://routerboard.com/RB911G-5HPacD-QRT
DynaDish 5 ----http://routerboard.com/RBDynaDishG-5HacD
hope this can cover all your questions
ismets
Tue Jun 16, 2015 12:30 pm
Hi RochNight13
Is it same RBSXTG-5HPacD.It have 16 DBI gain and 28 degree antenna.
All side for PtoP.
This http://routerboard.com/RBSXTG-5HPacD
Other side QRT and Dish is good.Some forum post i read more than 10Km for this items.
Saadbaadshah
Sat Sep 09, 2017 11:46 pm
Hy
I want best solution for coverage of 2km in bulding area to provide service on mobile wifi...
Kindly suggest me devices that i use?
I also use basebox2 but its not effecient ..
Users browsing this forum: mcfish and 26 guests
