cmanciu
100 megs connection... what board is needed
Wed Jun 17, 2015 6:19 pm
Right now I have 100 megs coming from the provider....I'm using rb433ah....just found out if I want 3 vlans I need a board where I can change the mtu on the ethernets.....which router board should i get.... any suggestions?
BartoszP
Re: 100 megs connection... what board is needed
Wed Jun 17, 2015 6:36 pm
RB951G-2HnD ?
RB2011 ?
Real admins use real keyboards.
To quote or not to quote, there is the topic: viewtopic.php?f=2&t=168474
chechito
Wed Jun 17, 2015 9:26 pm
in some posts many people have complains about rb 2011 or rb 951 performance for 100mbit Internet connections
i think rb850gx2 its better suited for that kind of load
cmanciu
Sat Jun 20, 2015 6:51 pm
that sucks...i already ordered the 951
CyberTod
Long time Member
Long time Member
Sat Jun 20, 2015 6:58 pm
For a typical home setup with fasttrack enabled it is more than enough. I can do 98mbit/s with 20% cpu usage on my home connection. And my wan interface is 100mbit ethernet so it is capping it with no problem.
P.S. This is with a 951Ui
vortex
Sat Jun 20, 2015 7:18 pm
I do 250Mbps at 50% with RB2011 and fasttrack. 220-240Mbps at 100% without fasttrack.
soyelpulpo
Sun Jun 21, 2015 11:12 am
Try this get one with gig ports
Sent from my Nexus 4 using Tapatalk
chechito
Mon Jun 22, 2015 2:58 am
ok with fast-track will be no problem, but using firewall or queuing the performance will be limited on rb2011or rb951 because of 600mhz single core cpu CPU, the next mikrotik in terms of performance is the rb850gx2
cmanciu
Mon Jun 22, 2015 6:05 pm
Thank u
ericnyamu
Sat Jul 25, 2015 11:37 pm
A routerboard ? Seriously is there an RB that does less than 100mbps in this day and age ?
normis
Mon Jul 27, 2015 11:24 am
Any RouterBOARD device is capable for this, RB951 included
Users browsing this forum: Baidu [Spider] and 50 guests
