azurtem
Trainer
Trainer
NV2 Compatible antennas
Thu Jun 18, 2015 5:20 pm
Hi
I'm trying to connect SXT Lite 5 station bridges with a NetMetal 5 (bridge) that is connected to a RFElements Sector Carrier Class 5-17 antenna
I can't get the SXT and NetMetal 5 to connect via NV2
Is this normal ?
Can all antennas operate with NV2 protocol ?
thanks
yann
jmontero
Re: NV2 Compatible antennas
Fri Jun 19, 2015 2:01 pm
The Antenna doesn't affecto to the Transmission Protocol... Your problem must be that if the Link has a lot of interference, with NV2 you will get worst behaviour than with 802.11. Try to change the channel.
azurtem
Trainer
Trainer
Fri Jun 19, 2015 2:13 pm
thanks jmontero
n21roadie
Fri Jun 19, 2015 11:43 pm
NV2 has come a lot way since its introduction and I find now NV2 is much more resilient to interference than 802.11
N21roadie,
Network 100% MT for Now?
pukkita
Trainer
Trainer
Sat Jun 20, 2015 12:47 am
Which wireless mode are you setting on each end?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
azurtem
Trainer
Trainer
Sat Jun 20, 2015 6:42 pm
nv2
azurtem
Trainer
Trainer
thanks n21roadie
pukkita
Trainer
Trainer
Tue Jun 23, 2015 1:08 am
Make sure the netmetal has a recent ROS and firmware versions.
Can you post /interface wireless export for both the netmetal and SXT?
Users browsing this forum: No registered users and 38 guests
