MUM Europe 2020
ohara
Working MicroSD for RB450G 6.28
Sun Jun 21, 2015 5:59 pm
could anybody please recommend a microSD card that actually works with RB450G 6.28+ including brand and density? Much appreciated.
purana
Re: Working MicroSD for RB450G 6.28
Mon Jun 22, 2015 1:50 pm
Have you tried some and had no luck? or is that a general question before you buy one? I have a RB405G and I haven't yet put a card in. I probably should, but I think it was on the underside of the board, so I didn't want to pull it apart (shutting down my link) to do it.
ohara
Mon Jun 22, 2015 9:23 pm
I tried a Medion 8GB card. The RB discovered the card, but it disappeared after a few attempts to format it. Any advice would be appreciated. Does anybody have experience with Kingston microSD and RB450G?
ohara
Tue Jul 07, 2015 9:04 pm
just asking again? Are you using a microSD card with RB450G? can you please recommend what card it is? much appreciated.
purana
Thu Jul 09, 2015 1:25 pm
I haven't got one installed in my unit. Perhaps I should pull it out of the case and install it. I would tend to stick good known brands like Sandisk etc.
I have an 8gb card somewhere, I will try to install it in the next few days and let you know how I go.
ohara
Sun Jul 12, 2015 4:17 pm
Hi purana, please let me know the sandisk card was working? Did you have time over the weekend to test? Much appreciated.
purana
Thu Jul 16, 2015 1:57 pm
I used a Kingston 16GB microsd class 10 card and formatted it as ext3. Seems to be working fine. Had to reboot after the format for it to detect again.
What else can I use the extra space for? I noticed you can use it for http proxy cache, can you create folders on it? Guess I need to tinker some more.
ohara
Fri Jul 17, 2015 7:21 pm
Thanks for your comments. I use it for small daily DB backups.
Users browsing this forum: No registered users and 12 guests
