Niex
Script for reboot based on wireless clients
Mon Jun 22, 2015 8:54 pm
Needs a script to reboot a Omnitik when registered clients = 0 on wlan interfaces e ou virtual ssid´s.
Thanks in advance
jarda
Tue Jun 23, 2015 3:35 pm
And what? I see easier to check the interface status as the interface doesn't report running state when no clients connected. It's quite similar. So what problem do you have with your script?
wcsnet
Tue Jun 23, 2015 6:49 pm
Dude of no one replies send me a mail ill write it for you when i have some time you can then come post it here werner.venter.mail@gmail.com.
Sent from my iPhone using Tapatalk
Niex
Re: Script for reboot based on wireless clients
Fri Oct 02, 2015 11:30 pm
:local clientes [/interface wireless registration-table print count-only];
:local WarnAt 0
#:log info ($clientes);
:if ($clientes <= $WarnAt) do={
/system reboot
n21roadie
Sat Oct 03, 2015 4:21 pm
:local WarnAt 0
/system reboot
But what happens on reboot > before clients can register script runs and reboot again > on reboot >repeat loop
Put in a delay of say 5mins on the scheduler after router reboots to allow for clients to register before script becomes active ?
N21roadie,
Network 100% MT for Now?
mousa1983
Sat Oct 03, 2015 9:08 pm
Why you need to Reboot?
what is problem?
Niex
Wed Dec 09, 2015 2:49 pm
All clients are disconected and not concect anymore.
p3rad0x
Long time Member
Long time Member
Tue Jan 05, 2016 3:29 pm
What do you see in the omnitiks log file when the clients drop?
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
NetHorror
Mon May 23, 2016 10:04 pm
:local WarnAt 0
/system reboot
many thanks :)
MTCNA, MTCRE, MTCTCE, MTCWE
a7mad78
Tue Aug 09, 2016 9:30 am
:local WarnAt 0
/system reboot
Great but how i can make it reboot when
there are 0 active users in the hotspot ?
i tried to do some adjustments but it didn't work firstly ,
second i don't have a good skills in programming :)
this is how i made my adjustments
:local clientes [/ip hotspot active-table print count-only];
:local WarnAt 1
/system reboot
i want to make the mt reboot when the active users reaches 0
i think i have a mistake in the first lane :) but i don't how i can correct it
Thx,, <3
a7mad78
Tue Aug 09, 2016 9:35 am
Oh, never mind :)
my problem was actually in the first line :)
i edited it
from
to
and do i have to run this script after every reboot or it will still running ?
Users browsing this forum: No registered users and 16 guests
