normis
Leap Second issue on CCR units
Fri Jul 03, 2015 8:37 am
Unfortunately, there was a bug in our NTP package that caused a crash on CCR units due to the introduction of the Leap Second on June 30, 2015. This bug did not cause any other problems. We have fixed the issue in RouterOS v6.30rc26. No other devices were affected, only CCR units.
We are sorry for the inconvenience, please upgrade the devices when the new v6.30 version comes out, or upgrade to the RC now, if you prefer to get the fix sooner. The fix will also prevent any problems with further leap seconds in the upcoming years.
In addition, we also improved the Watchdog to do it's job better and make sure the devices are rebooted in this type of crash.
Download v6.30rc26 here: http://www.mikrotik.com/download/share/ ... 30rc26.npk
joegoldman
Re: Leap Second issue on CCR units
Fri Jul 03, 2015 3:51 pm
Hi Normis,
I had CCR unit running NTP updates on 6.27 that did not crash?
I purposefully disabled SNTP on my primary routers but left it on my secondary's to see if they would be affected but they were not.
CCR1036-8G-2S+ running 6.27
normis
Fri Jul 03, 2015 3:59 pm
It is possible that your NTP server did not send a "Leap Flag" but simply sent new corrected time, it depends on the server.
kgninfos
Fri Jul 03, 2015 4:57 pm
My ccr did crashed on 30th June midnight
after rebooting it worked fine
IPANetEngineer
Trainer
Trainer
Fri Jul 03, 2015 7:45 pm
Thanks for the patch guys....will test it out soon.
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
tsedes
Mon Mar 07, 2016 7:49 am
HI,
I have same issue here, my CCR was Crash and must power restart to make it UP. But, I thing my problem is diff because there is no ntp client or server enable. This happen periodically but random. there is no CPU load issue.
anyone have my experiece to?
paulct
Fri Dec 30, 2016 12:24 pm
Just a bump..... leap second on the 31st of December 2016. Make sure your CCR's are upgraded before then.
Chupaka
Fri Dec 30, 2016 2:29 pm
huh... Normis, please confirm that the bug is in NTP package, and SNTP client is not affected
or should we better disable SNTP client for a day or two on pre-6.30 versions?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
normis
Fri Dec 30, 2016 2:30 pm
the old bug was in the NTP package (affected only multicore systems). but it was fixed after 6.30
pe1chl
Fri Dec 30, 2016 3:36 pm
So our CCR with ntp package version 6.37.3 will not crash tomorrow night? Promise? :)
normis
We did test it again, so I hope it will be ok :D
paulct
Fri Dec 30, 2016 4:49 pm
Mine is on 6.30.1 - holding thumbs :)
pe1chl
Sun Jan 01, 2017 2:19 am
Our CCR made it OK... Happy new year!
Users browsing this forum: No registered users and 4 guests
