What behaviour of counters on fasttracking rules do you want?
I want no dummy rules. Each rule should count its own counters correctly.
80 (39%)
I want non-removable one dummy rule for all fasttracking rules to display summary values and real rules can show nonsenses further.
3 (1%)
I want one dummy rule for each fasttracking rule to display values individually (as many dummy rules as many real fasttracking rules).
8 (4%)
I want to have general option to enable or disable this dummy rule.
93 (46%)
I want to have an individual option in each fasttracking rule to invoke corresponding dummy rule for counting values.
19 (9%)
Total votes: 203
jarda
Feature request: Remove fasttrack dummy rule
Sat Jul 11, 2015 12:28 pm
I am absolutely against having general accepting rule in forward chain, that I cannot remove:
Everyone that sees it must think that it is accepting all traffic in forward chain.
I dont know if it is really accepting or not. This makes big mess in firewall, to have "dummy" rules that (hopefully) do nothing. How can I be sure???
Please, remove it as soon as possible, or at least make it selectable for example in real fasttracking rule open an option to invoke dummy rules for those who want it and keep the firewall otherwise clean without such garbage.
I am using more than one fasttracking rules and such one dummy accepting rule does not say anything. I have asked several times and had not get answer, so asking again:
Why the fasttracking rules do not count their hits but count something different? Make them count correctly and you do not need any dummy rules!
I am creating the polling question. As the answers are not fully disjunctive, everyone can select up to 2 answers.
Thank you very much.
G2Dolphin
Re: Feature request: Remove fasttrack dummy rule
Sat Jul 11, 2015 2:16 pm
Not only these rules are mess for some people (including me), they are just cannot be deleted! Considering everything (obviously excluding some deep system things) in ROS can be set up by us, this is a step backwards.
I can understand these rules if they were unique. But they are just showing the same information that in "IP - Settings". I'm not too lazy to go there and see, if I need. But I don't need that info be forced.
CCR1009-7G-1C-1S+PC, RB3011UiAS-IN (2011 case+3011-RM), hAP ac, mAP2n/mAP2nD, wAP LTE (Huawei ME909s-120)
There's nothing wrong with your Internet connection, I have broken avatar. :)
jarda
Sat Jul 11, 2015 8:44 pm
I hate settings that do not have any real reason but cannot be removed too.
The ipsec policies and proposals that cannot be removed even there is not used ipsec on the device at all, for example. But it is another topic...
lordkappa
Sat Jul 11, 2015 11:20 pm
This feature should be nixed. Not even optional, just removed.
Having a do-nothing rule in firewall because your OS can't correctly track fastpathed traffic is just kludgy and unprofessional. As stated before, the same counters are available in ip->settings.
vortex
Sun Jul 12, 2015 12:09 am
I imagine this was a quick workaround for what some people were missing and that it will be cleaned up in a future release, but maybe not in 6.30.x .
G2Dolphin
Sun Jul 12, 2015 8:25 am
Why not? It's not a really complex problem. But it's MikroTik choice anyways — to remove it, or not.
bajodel
Long time Member
Long time Member
Sun Jul 12, 2015 9:11 am
+1 ..up
vortex
Sun Jul 12, 2015 1:03 pm
Maybe they would fix it, but not in 6.30.x because it might imply an architectural change.
andriys
Sun Jul 12, 2015 6:53 pm
I'd like to support you and vote against the dummy rules, which are undoubtedly just a mess. I would have vote for option #1, but your wording is quite misleading. Your "Each rule should count its own counters correctly" implies the rule's packet/byte counters are incorrect, but in fact they aren't! What real rule counters show you is perfectly correct. You just need to understand what they show exactly. And Mikrotik needs to document that stuff in a clear way.
As I understand, things work as follows:
  1. If packet matches a fasttracked connection, it is not being processed by the firewall at all. Just accepted. Thus no rule's counters are being updated when such packets are being processed by your router.
  2. A rule with 'action=fasttrack' (fasttrack rule) just marks the corresponding connection-tracking entry for fasttrack. The packet hitting a fasttrack rule is not being fasttracked yet, and thus updates the rules' counters.
  3. A fasttrack rule does not automatically imply 'accept', effectively passing the matching packet through. If you have an accept rule immediately following the fasttrack rule with the same traffic selectors, the hit and byte count on both rules is always the same. This is perfectly normal and expected.
TomosRider
Mon Jul 13, 2015 12:14 am
Im with you Jarda.
macgaiver
Mon Jul 13, 2015 9:44 am
It looks like person that that made this pool doesn't know how fasttrack works:
There will be no difference in counters for other rules - as soon as you enable fasttrack, fasttracked traffic will skip firewall - will not be counted in any rules, will be invisible in firewall and queues, that is how fasttrack works, so with and without fasttrack dummy rule other rules will count exatly the same amount of traffic.
Same as before..., only small fraction of traffic will go through firewall with fasttrack, and dummy rules have no effect of "nonsense further"
Fasttrack-connection works with connections, similar to connection-mark, you don't know how many rules are marking your traffic with the same mark, it is impossible.
I can agree to this option, but be ready that there will be someone that will report that traffic is missing in firewall and queues as soon as you disable it.
Already stated before - it is impossible as fasttrack is binary flag in connection tracking you can't say what rule added the flag.
Bottom line, If you use fasttrack, most of the traffic will take the shortcut, skipping your firewall counters and queues, that is the way it works.
So fasttracked traffic is invisible for firewall and queues. To make it visible dummy rule was added.
so the pool options should be
a) i like dummy rules it allows me easier to see all my traffic in the firewall
b) i don't like dummy rules, i can live with traffic that is invisible to my firewall and queues
c) i like option that allows me enable/disable dummy rules
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
jarda
Mon Jul 13, 2015 10:50 am
Sure I am the person that does not know everything. And probably I do not fully understand the fasttrack counting approach.
I know that the fasttracking rule more or less works like mange and once the connection is marked it bypasses the firewall.
But: If there is possibility to count the values and display them in dummy rule, the values could be displayed on real rules instead on the dummy ones.
I am mainly against the forced dummy rules. If I would like to have such rule in firewall or in mangle, I would like to put it there on my own. Maybe some other options are not smart enough, but it is interesting anyway what people vote for...
macgaiver
Mon Jul 13, 2015 11:05 am
It is a workaround, you can't get those counters any other way manually, you need to go to /ip settings to see them
Check console, it have better representation. of that rule, winbox view can be misleading i agree.
andriys
Mon Jul 13, 2015 12:35 pm
Dummy rules show cumulative fasttrack counters (i.e. grand total bytes/packet fasttracked). You may have more then 1 fasttrack rule in your configuration, and showing the same number of packets/bytes on all your real fasttrack rules will be even more misleading then it is now with the fake (dummy) rules. Making fasttrack update per-rule counters is not an option, I think, as that should be quite expensive, while fasttrack is all about performance.
jarda
Mon Jul 13, 2015 1:25 pm
Maybe it is correct, but you never know. We are not ros developers.
The counters are held in conntrack on each connection individually. Maybe it is possible to number internally the fasttracking rules and add this number to each connection in conntrack while marked as fasttracked connection to be able to distinguish to which fasttracking rule the connection belongs. Then the regular counting would be easy and almost as fast as in total. This could be a way that mikrotik can solve my request, I think...
I guess that the counting is not part of firewall but part of conntrack anyway. So I still see possibility to get the right values where they should be.
macgaiver
Mon Jul 13, 2015 1:35 pm
Already there.
marting
Mon Jul 13, 2015 4:00 pm
Where do these rules come from? I have some RB2011 with these rules and some RB2011 without these rules. All are running 6.30
These rules caused real headache because my configuration script does something like:
1. disable all interfaces
2. clear all firewall rules (filter, nat, mangle)
3. do something more
4. enable specific interfaces
Of course my script fails at this point:
[admin@INCOMPLETE_CONFIGURATION] > :foreach item in=[ /ip firewall filter find ] do { /ip firewall filter remove $item }
failure: cannot remove builtin
[admin@INCOMPLETE_CONFIGURATION] > :foreach item in=[ /ip firewall mangle find ] do { /ip firewall mangle remove $item }
I will change it to delete only non-dynamic rules. But it would be interesting to know.
Edit 1: These rules are not there when I do a /system reset-configuration no-defaults=yes . So I do not understand why they are separatly handled as "built-ins"
jarda
Mon Jul 13, 2015 5:18 pm
Looks like it is another unwanted effect of such "dummy" bad things.
harn2412
Tue Jul 14, 2015 11:54 am
I only a new with RouterBoard and only test for a little with fast-track. And this is my think about dummy rule:
- I like this dummy rule because I can get a look over all fast-track streaming. I do not see the need to be monitored on a fast track streaming.
- But I also like the option to disable/enable this rule when I see don't need them.
jarda
Tue Jul 14, 2015 12:38 pm
It means you want the non-removable dummy rule as it is in 6.30 at the moment and simultaneously you want to be able to remove such non-removable dummy rule? Is not that contradictory?
macgaiver
Tue Jul 14, 2015 12:43 pm
Rules show up as soon as you have at least one fasttrack connection in connection tracking table
(so basically as soon as you create fasttrack-connection rule in your firewall).
Dynamic dummy rules will remain there until you have at least 1 fasttrack connection remaining in connection tracking table
(yes, even after you disable your fasttrack-connection rule, cause if connection is fasttracked it can't be redirected back to normal path)
you will need to reboot
to Jarda: i think everyone in the forum already got your point about these rules, there are no real need to spam every topic
jarda
Tue Jul 14, 2015 1:31 pm
Where have you seen my spam?
jarda
Mon Jul 20, 2015 10:22 am
Ok,
a week has passed. Now the result look quite clear.
People here want to be able to switch the dynamic rules off and want each rule to show its values correctly instead those dummy rules.
Normis, what is your answer to this?
doush
Long time Member
Long time Member
Mon Jul 20, 2015 1:22 pm
Actually we want MT developers to explain us in DETAIL of how fasttrack works with several examples and clear description.
macgaiver
Mon Jul 20, 2015 3:39 pm
what is not clear? i think it is straight forward.
Take a look at packet flow diagram:
http://wiki.mikrotik.com/wiki/Manual:Packet_Flow_v6
first packet of the connection tracking goes through the regular routing forward.
all next packets from this connection goes directly from Physical in-interface, to physical out-interface, with some imaginery Fastpath box in the middle. So basically skipping everything in the path.
macgaiver
Mon Jul 20, 2015 3:44 pm
Ok,
There are no normal answers there. 3 or 4 of them are basically implying the same thing.
Answers need to be:
1) Yes, i like dummy rules, i see that they can be useful (not possible in your pool)
2) no, i don't like dummy rules, i thing they sould be disabled
3) Option to disable/enable dummy rules should be implemented
4) i do not care, i just want to see pool results.
Then we can talk about pool objectivity.
I just received my first board from distributors with default configuration that had fasttrack enabled by default, without dummy rules i wouldn't even realize that i fasttrack is implemented already.
jarda
Mon Jul 20, 2015 9:17 pm
Maybe my questions are not the best questions that could be asked in this topic (and I agree with it), but the message is clear:
- not to force unremovable dummy rules
- show the values on the rules where they belong to
When receiving new device, you should wipe the config rather than searching for the dummy rules. Or is it fasttracking suddenly somehow without fasttrack rules? I doubt it. If there are fasttracking rules, you can see them, so you do not need additional rules that would show you what is already there...
Ansy
Tue Jul 21, 2015 1:43 pm
Does just renaming that dummy accept rule to account rule solve the problem?
macgaiver
Tue Jul 21, 2015 2:32 pm
In reality (if you print in console) there are no action at all. I think accept is default value in winbox. and that is only thing that need to be changed.
G2Dolphin
Sat Sep 12, 2015 3:22 am
So... 6.33rc5 now, still no changes on this topic. MikroTik, will you do something with these rules, or they're solid now?
koshak83
Location: Russian Federation, NWFD, Saint-Petersburg Federal City
Mon Oct 05, 2015 4:13 pm
Seriously, remove this rule. It infuriates. If a user is interested to see this information- he will look it here in Fast Path/Fasttrack section http://demo.mt.lv/webfig/#IP:Settings
techieg33k
Fri Oct 30, 2015 10:46 pm
Marting I had the same issue I finally got fixed. I am not sure if you or others finding this post still need a solution, but the below lines are direct replacements for your lines that fail. The following has been tested on 6.32.3 with the following hardware: RB951Ui-2HnD, RB751U 2HnD, and RB751G-2HnD
:foreach item in=[/ip firewall filter find] do={:if ($item != "*8") do={/ip firewall filter remove $item;}}
:foreach item in=[/ip firewall mangle find] do={:if ($item != "*3") do={:if ($item != "*2") do={:if ($item != "*1") do={/ip firewall mangle remove $item;}}}}
Chupaka
Mon Nov 02, 2015 10:54 am
just replace "/ip firewall filter find" with "/ip firewall filter find dynamic=no", using item ids (like "*8") is router-dependent
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
jo2jo
Forum Veteran
Forum Veteran
Mon Dec 10, 2018 2:23 am
i like the FT dummy rule. there have been a few times ive added fasttrack to older RBs that DONT support it, the ONLY way i was able to notice this was by seeing the dummy rule was not increment at all.
:beep :beep :beep
Users browsing this forum: Majestic-12 [Bot], nik247 and 112 guests
