awgur2008
Feature Request: Tincvpn
Sat Jul 11, 2015 2:21 pm
I'm requesting that tincvpn be included in ROS 7.
awgur2008
Re: Feature Request: Tincvpn
Wed Jul 15, 2015 7:58 pm
What is tinc?
tinc is a Virtual Private Network (VPN) daemon that uses tunnelling and encryption to create a secure private network between hosts on the Internet. tinc is Free Software and licensed under the GNU General Public License version 2 or later. Because the VPN appears to the IP level network code as a normal network device, there is no need to adapt any existing software. This allows VPN sites to share information with each other over the Internet without exposing any information to others. In addition, tinc has the following features:
Encryption, authentication and compression
All traffic is optionally compressed using zlib or LZO, and OpenSSL is used to encrypt the traffic and protect it from alteration with message authentication codes and sequence numbers.
Automatic full mesh routing
Regardless of how you set up the tinc daemons to connect to each other, VPN traffic is always (if possible) sent directly to the destination, without going through intermediate hops.
Easily expand your VPN
When you want to add nodes to your VPN, all you have to do is add an extra configuration file, there is no need to start new daemons or create and configure new devices or network interfaces.
Ability to bridge ethernet segments
You can link multiple ethernet segments together to work like a single segment, allowing you to run applications and games that normally only work on a LAN over the Internet.
Runs on many operating systems and supports IPv6
Currently Linux, FreeBSD, OpenBSD, NetBSD, MacOS/X, Solaris, Windows 2000, XP, Vista and Windows 7 and 8 platforms are supported. See our section about supported platforms for more information about the state of the ports. tinc has also full support for IPv6, providing both the possibility of tunneling IPv6 traffic over its tunnels and of creating tunnels over existing IPv6 networks.
http://www.tinc-vpn.org/
guglez
Wed Oct 26, 2016 2:15 pm
I'm also interested.
dlausch
Thu Jan 05, 2017 1:46 pm
This would be a very nice feature....
Security is just a appearance....
jarda
Thu Jan 05, 2017 3:44 pm
Interesting. But it would be very difficult to integrate with the ros I am afraid.
3XTron
Sun Sep 24, 2017 9:56 pm
Does it make sense to create addition package with TINC VPN for RouterOS like in PFSENSE or OPNsese ?
Since RouterOS does not have a full mesh VPN option and in current state need to make workaround.
Please add it in RouterOS7 todo list.
Contributor at Unetlab and EVE-NG porjects
fragtion
Wed Dec 06, 2017 3:28 pm
I second this notion. tinc would be a very valuable addition to RouterOS's feature list, even if it were an optional pkg
idearia
Tue Mar 06, 2018 7:29 pm
I created an account just to second this feature request ;-)
I work in a web agency; we install MikroTik routers in our clients locations to act as WiFi hotspot for their own clients.
We would like a way to control the routers remotely (ex. forcing reboot, change SSID password if compromised, etc) without the need to open ports in the client's DSL routers.
We could do this if we were able to install tinc on RouterOS.
Thank you for your attention,
Guido
ela002
Tue Apr 24, 2018 10:44 am
juanquy
Wed Jun 27, 2018 10:33 pm
it will be a valuable addition to RouterOS, let do it! :)
Ertong
Wed Jul 11, 2018 2:39 pm
Tinc VPN looks like the most simple and effective way to connect several offices into one network.
As far as I know, for now, similar thing can be done by manually creating n^2/2 tunnels between routers + NAT hole punching is an extra task.
TincVPN should be much simpler and more stale way to go.
+1 for this feature
alexmartini
Sun Jul 29, 2018 8:10 pm
Guido
I do this with pptp.
Enviado de meu LG-K430 usando o Tapatalk
gotsprings
Mon Jul 30, 2018 3:47 am
I have waited 10 years for Open VPN to get proper emplimentation.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
mmatusko
Fri Oct 12, 2018 11:27 am
alijorjani
Thu Sep 12, 2019 9:26 pm
tincvpn as DMVPN for Mikrotik
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot] and 38 guests
