spaxton
Mobile Router AP hardware suggestion
Thu Jul 30, 2015 1:40 pm
Hello everyone,
Since there are more and more needs for mobile internet, I got an idea about mobile router. I have placed many RB951 with USB LTE modem but it is not so mobile, it's big and it has to be plugged somewhere so my suggestion is to make a small router with integrated battery and LTE interface. Should have not more than 2 LANs and, of course, one USB port to plug the phone to charge the battery. :)
Best Regards!
jarda
Thu Jul 30, 2015 3:21 pm
I don't believe it will be built by mikrotik. But maybe one day after three years we all can be surprised.
djdrastic
Re: Mobile Router AP hardware suggestion
Thu Jul 30, 2015 3:54 pm
Look for TP Link Devices.
You get ones with as big as your hand with 1-3 hour battery backup services.
Wireless tends to be kinda weak on these units though.
marrold
Thu Jul 30, 2015 4:40 pm
The Map2n is pretty close, just add your own battery
spaxton
Thu Jul 30, 2015 5:15 pm
Yes, it is but then I should have to take modem and battery... Thats 3 separated parts. ;).
BTW, I know about all other brands who produce this kind of devices... I would like to have mikrotik. ;)
jarda
Thu Jul 30, 2015 10:54 pm
Anyway almost every android phone is able to host the tethering hotspot right out of the box. With battery but without built in ethernets.
spaxton
Re:
Thu Jul 30, 2015 11:13 pm
Have You ever heard for MiFi router? :)
jarda
Fri Jul 31, 2015 12:32 am
Yes. I heard a bit about it. So what?
spaxton
Re:
Fri Jul 31, 2015 12:35 am
So, Android phone can't replace it 100% with functionality. Especially if we consider dataplan for mobile users. Mostly operators offer data card with special pricing which is not able to make phone calls. ;)
jarda
Fri Jul 31, 2015 12:40 am
Sure you are right. But I don't believe you can expect such device from mikrotik soon.
spaxton
Re:
Fri Jul 31, 2015 3:13 am
Maybe not soon but sure I do expect. :) Why not? I'll buy it as soon as they release it.
