kgninfos
Wireless Access Point preference
Fri Jul 31, 2015 8:52 am
Hello
is there a way i can set a predefined list of access point to whom the SXT will connect (will connect to the access point with Max Signal to noice ratio) we want to automate the process of CPE installation where we don't have to scan and connect to an Accesspoint at site rather just mount it and it will connect to the access point with Max Signal
most important is once connected to an accesspoint it will not change to another one till reboot
Thanks in advance
lambert
Long time Member
Long time Member
Re: Wireless Access Point preference
Sat Aug 01, 2015 6:27 am
kgninfos
Sat Aug 01, 2015 6:30 am
the problem is it will check the list sequentially so will connect to first available access point
want i want is it should connect to the access point with max signal strength
lambert
Long time Member
Long time Member
Sat Aug 01, 2015 7:18 am
Different SSID per sector or only per tower?
2 ideas:
Number 1:
Set all of the connect list entries to disabled.
Write a script to
1. scan for APs
2. determine which one has the strongest signal
3. set the appropriate connect list entry to enabled
Maybe?
Number 2:
Setting the signal level to your minimum allowed for new installs, or a few dBm higher, for each connect list entry might do it for you except when your install is in the overlap area between two sectors. Your techs might have to log into it to pick the right AP if the signal is weaker than what you set. But, if you're using decently directional antennas, hopefully there wouldn't be too many times when it sees several of your APs above the level set in the connect list.
Users browsing this forum: almdandi, bpwl, Frost93, McSee, mixig, MSN [Bot], naywinaung, roboticpuppies, RusConSPb and 100 guests
