rwrocket
VPLS Tunnel won't pass traffic using OSPF NSSA
Tue Aug 04, 2015 5:47 am
Rather new to MPLS + VPLS on Mikrotik and trying to get it working for PPPoE delivery in my lab however I have run into a problem I don't think is MTU related.
For now I have removed all switches bridges etc while I try to troubleshoot why one of my tunnels is not passing traffic.
Here is the scenario
R3 =HEXlite ----------> R2 = RB2011 ---------> R1=CCR1036
********************EDIT******************
Above was my original post but now found out that if I change my OSPF area to default it works. But on NSSA it doesn't
Is this just the way it is ? I can live with it but would like to know if there is a way around it other than changing area type.
mrz
Re: VPLS Tunnel won't pass traffic using OSPF NSSA
Tue Aug 04, 2015 11:33 am
You need loopback address distributed to NSSA area from backbone. Otherwise VPLS tunnel will not be able to establish.
Either you change area to default or set translate-always and inject-summary-lsa.
ploquets
Thu Jun 09, 2016 12:44 am
Hello. Please, could you tell me where do I need to translate?
I'm on same scenario, trying to establish a VPLS tunnel between backbone and a NSSA area.
My NSSA area has normally two RB750 and 4 RB912 on each RB750.
What I need is to establish a VPLS tunnel on a RB912 <--> CHR (which is part of my backbone)
Thanks a lot!!!!
