sploit
OpenSSH7 Unable to negotiate with 192.168.1.1: no matching host key type found. Their offer: ssh-dss
Mon Aug 17, 2015 7:58 pm
Hi All,
Since installing OpenSSH 7 I've been unable to connect to my router though ssh pubkey authentication. Previous versions of OpenSSH still work. This is an issue for automated scripts using ssh.
I always get the following message returned:
Running RouterOS version: 6.28
Google tells me the following:
OpenSSH 7.0 and greater similarly disables the ssh-dss (DSA) public key algorithm. It too is weak and we recommend against its use. It can be re-enabled using the HostkeyAlgorithms configuration option:
ssh -oHostKeyAlgorithms=+ssh-dss user@127.0.0.1
http://www.openssh.com/legacy.html
But that is not working...
Could you guys possibly implement ssh-rsa?
Thank you for looking into this!
kas
Re: OpenSSH7 Unable to negotiate with 192.168.1.1: no matching host key type found. Their offer: ssh-dss
Tue Aug 18, 2015 8:55 pm
I also am in favor of supporting ssh-rsa in the next release. For now, you can override OpenSSH's defaults by adding the following two options.
-oHostKeyAlgorithms=+ssh-dss -oPubKeyAcceptedKeyTypes=+dsa
MartijnVdS
Wed Aug 19, 2015 10:48 am
According to the changelog, 6.31 supports RSA keys if you enable "strong crypto" for SSH (/ip ssh set strong-crypto=yes)
sploit
Sun Aug 23, 2015 4:20 pm
Just upgraded to 6.31 and tested with an RSA key, seems to be working :)
Users browsing this forum: LunaticRv, sindy and 75 guests
