Yasir
AAA Command Authorization
Fri Aug 28, 2015 1:40 pm
Hello All,
I need to stop Imagining the idea of being able to limit the access of users to do anything in the router when they are in "write" group , when i only need them to for example ( only able to change wireless settings ) , not Routing ... etc
The User AAA need to have authorization section to confirm every command
allow anything under /interface wireless
block any attempt under /system , /ip services
block attempts to user /interface ethernet disable
.... you get the Idea
If this is not existing ( if it is , please point me to the right direction ) then consider it as a Feature Request
Yasir
Re: AAA Command Authorization
Sat Jan 07, 2017 11:12 am
Wow , Much replies , so Empty , very Mikrotik :(
pe1chl
Sat Jan 07, 2017 12:39 pm
This is mainly a user forum. Sometimes MikroTik employees on the forum pick up feature requests
from here, but it is better to send them as mail to support@mikrotik.com so they will be filed and tracked as a
support ticket. When you have a business case for a new feature it will undoubtedly be considered.
ditonet
Forum Veteran
Forum Veteran
Sat Jan 07, 2017 2:27 pm
@Yasir
Use WebFig with skins.
HTH,
Yasir
Sat Feb 25, 2017 11:21 am
Thank you Ditonet , was hoping it is also usable in Winbox but still , surely can manage with that
