blougaville
client-to-client forwarding in CAPsMAN local forwarding mode
Sat Aug 29, 2015 7:12 am
I understand that when using local forwarding mode the client-to-client forwarding on a interface is not set with CAPsMAN, but is controlled by the local CAP.
The manual suggests that client-to-client forwarding needs to be set on the CAP itself, but I can't figure out how to do this. The wireless interface in the CAP (managed by CAPsMAN, local forwarding mode) has default forward checked, but client-to-client forwarding on that interface is still not working.
raffav
Re: client-to-client forwarding in CAPsMAN local forwarding mode
Mon Aug 31, 2015 4:43 pm
Hello
i am getting the same problem,
in local forwarding mode, client -to-client is not workting i cant ping any device on the same vAP interface,
Zwodka
Mon Aug 31, 2015 11:30 pm
As I know, you have to create and define a Bridge Interface on the CAP device
raffav
Mon Aug 31, 2015 11:43 pm
but it is alredy set,
Zwodka
Wed Sep 02, 2015 9:26 am
Pfff... I've no idea :-(
blougaville
Sat Sep 05, 2015 9:35 am
Mikrotik, can you please chime in on this? Your documentation says it's possible but does not say how.
Also, I can't find any good real world examples of why you would use CAPsMAN in local forwarding mode vs manager forwarding mode. I am using CAPsMAN on a CCR in a school with 30+ CAPs and am currently using local forwarding mode. What factors should be considered when deciding between local forwarding mode and manager forwarding mode?
raffav
Sat Sep 05, 2015 4:08 pm
Maybe the situation when the core router is not a mikrotik device (i.e Cisco )so you use the caps in local forward mode so the data go to the non mikrotik device and you use a less power mikrotik to manager the wifi settings in all in one place
And yes we need a example how to set client to client on local forwarding
There is no example on the Internet in this configuration
blougaville Maybe is better to open a support ticket ?
raffav
Tue Oct 06, 2015 8:34 pm
Hello
i am still trying to find the solution for that
any one ?
Users browsing this forum: No registered users and 49 guests
