stefanelul2000
OSPF not working on RouterOS v7.1 between 2 routers
Tue Dec 07, 2021 8:52 am
I have just upgraded to Router OS V7.1 on 2 of my routers and everything seems to work perfectly normal with the exception of OSPF.
OSPF works without any issues in Router OS v6.49.2 but I can't get it working in v7.1
I have attached the 2 router configs. For now I can only provide the configs as I have reverted back to v6.49.2. I can do testing only outside business hours.
HQ-Router
/routing ospf instance
add disabled=yes name=default-v3 version=3
add name=default-v2
/routing ospf interface-template
add area=backbone-v2 interfaces="Vlan10-LAN" networks=10.1.10.0/24/24
add area=backbone-v2 interfaces="Vlan88-VMs" networks=10.1.88.0/24
add area=backbone-v2 interfaces="Vlan90-Management" networks=10.1.90.0/24
add area=backbone-v2 interfaces="Vlan110-WorkVPN" networks=10.1.110.0/24
add area=backbone-v2 interfaces="Vlan120-PulseVPN" networks=10.1.120.0/24
add area=backbone-v2 interfaces=GRE-Branch-RDS-RDS networks=172.22.22.0/30 type=ptp
/routing ospf area
add instance=default-v2 name=backbone-v2
add disabled=yes instance=default-v3 name=backbone-v3
Branch-Router
add name=default-v2
add area=backbone-v2 interfaces="LAN Bridge" networks=192.168.100.0/24
add area=backbone-v2 interfaces=GRE-HQ-RDS-RDS networks=172.22.22.0/30 type=ptp
/routing ospf area
Am I doing something wrong or am I missing something ?
The idea is that the routers are seeing each other (OSPF wise), but they are always stuck on neighbor state = ExStart and they are not getting past that point.
smyers119
Re: OSPF not working on RouterOS v7.1 between 2 routers
Tue Dec 07, 2021 2:08 pm
I am running ospf with no issues over here on 7.1
# dec/07/2021 07:05:32 by RouterOS 7.1
# software id = IZUY-SLWC
# model = RB4011iGS+
# serial number =
add name=default router-id=10.172.255.1
/routing ospf area
add instance=default name=default
add area=default networks=192.168.2.0/24 passive
add area=default interfaces=loopback0 passive
add area=default networks=10.172.2.0/24
mixig
Wed Dec 08, 2021 12:31 am
ExStart state; in most cases is if different MTU is on the link between routers.
Is there anything in the log?
mike7
Sat Dec 25, 2021 5:34 pm
looks like firewall rule is required:
add action=accept chain=input in-interface=<change_me> protocol=ospf
hammy559
Thu Dec 30, 2021 2:03 am
Not just you having an issue with OSPF on v7. I was unable to run it over a tunnel where v6 worked fine before so I had to revert the upgrade. Hope these things are fixed soon
viewtopic.php?t=163203
viewtopic.php?t=181377
Users browsing this forum: No registered users and 3 guests
