Dude2048
Re: DUDE v7 server "needed packages are not available"
Tue Jun 07, 2022 8:56 pm
Hello, in MikroTik v7 DUDE still can't upgrade Devices - Dude server still shows "needed packages are not available", though packages are uploaded on DUDE server in dude path.
Somebody any solution please?
marianob85
Tue Jun 07, 2022 9:24 pm
Still the same in 7.3!!
rextended
Wed Jun 08, 2022 12:27 am
No one has described on what exactly path have put the files, and what files...
Dude2048
Wed Jun 08, 2022 9:17 am
When the files are in the old location with V6 it works fine. With V7 you will get the option to upgrade but it triggers "needed packages are not available" and doesn't do anything.
To be a bit more precise; For me it is the CHR package which triggers this.
sulicz
Thu Jun 09, 2022 12:56 pm
I have the same problem.
I uploaded to dude server file routeros-7.3-arm.npk but in packages is visible as system. All connected routers in v7 have in packages routeros not system. So that is impossible to make upgrade. (in version 7.2.3 and 7.3 for me now)
andacb
Fri Jun 10, 2022 7:57 pm
Let me join you all. I have the very same problem since upgrade to v7. :)
Andaç
Dude2048
Fri Jun 10, 2022 9:43 pm
Created sup-84404
AUsquirrel
Sat Jun 11, 2022 6:22 am
Same here.
I have placed the packages on my dude server in the /dude/files directory on my router that is the dude server.
They are visible in the dude via the client in the Content - Files under files All and in the packages tab.
Still get the error "needed packages are not available
rextended
Sat Jun 11, 2022 11:30 am
The problem is now known (and known why it does so) and reported.
Hope MikroTik does something about it.
viewtopic.php?t=186567#p938935
Dude2048
Mon Jun 13, 2022 11:01 am
Answer from MT:
Hello
Yes, unfortunately, currently in the Dude it is not possible to upgrade devices by using v7 packages.
Best regards
I asked them if it will be fixed in future releases.
Dude2048
Mon Jun 13, 2022 11:02 am
And another answer:
Hello
We will try to resolve this problem as soon as possible in the future Dude releases when we will be working on fixes and improvements regarding this service.
Best regards
pe1chl
Mon Jun 13, 2022 11:25 am
I thought there was no more Dude development and thus no future Dude releases?
Well, of course the answer is still correct then...
Dude2048
Mon Jun 13, 2022 11:27 am
I know. I have seen the statement from Normis, but it never hurts to try.
rextended
Mon Jun 13, 2022 12:14 pm
The problem IS NOT DUDE:
AUsquirrel
Mon Jun 13, 2022 12:55 pm
Hi rexended,
I had a browse through the .npk package to locate the file you mentioned, where in the package should it exist? I didn't find an internal system description file.
rextended
Mon Jun 13, 2022 2:54 pm
read twice the post: if "internal description of .npk file"
Starting offset 0x20 (114)
for example on v6 mibsbe is
>routeros-mipsbe<
and each platform have it's own string
instead on v7 REGARDLESS THE PLATFORM
>system·········<
· is padding 0x00
you can not do any, the .npk files are digitally signed, and if you alter something, routeros do not install it (if the dude recognize it or not, not mind)
pe1chl
Mon Jun 13, 2022 5:41 pm
I don't know if they now properly sign the entire file instead of just the content. In the past it was possible to hack .npk files by changing header fields and RouterOS would not notice it.
sulicz
Wed Jul 20, 2022 2:17 pm
It comes version 7.4 ... problem remains.. :(
inteq
Fri Aug 26, 2022 12:49 am
7.4.1 same story
And I have a lot of devices to update...
nkm
Fri Sep 02, 2022 4:43 pm
7.5 same bug
golimh
Tue Sep 06, 2022 6:26 am
I have same bug in ROS 7.5 with several devices.
Rohan1997
Sun Oct 30, 2022 6:45 am
7.6 same bug
What's other way to upgrade ROS in group?
bloon
Wed Dec 21, 2022 2:54 pm
I have some bash script that can be used for mass upgrade.
It still need to input credential and hostname by hand, but at least it make more fast than manual upgrade.
https://github.com/vodafschuler/ros-upgrade
hope it help.
skullzaflare
Wed Jan 04, 2023 4:32 pm
I noticed as of v7 the DNS override self hosting "check for updates" server breaks too. They just hang at "calculating download size..." and never continue
If i change it back to v6 it still works fine
Really wish the DUDE was fixed for this, the DNS override was just a backup for missed routers
(reference to what I am talking about https://jms1.net/mikrotik/Mikrotik%20Update%20Server.md)
kramegroeg2021
Mon Jan 30, 2023 7:40 pm
Is there any update on this? Can I install the Dude server on a Linux server and then point it to the Mikrotik router interfaces?
stmx38
Long time Member
Long time Member
Wed Feb 01, 2023 10:55 pm
System requirements for server package
RouterOS:
v6.34rc13 or newer
Hardware:
TILE devices;
ARM devices;
MMIPS devices;
RouterOS x86 installations;
RouterOS CHR environment
sulicz
Mon Feb 27, 2023 7:11 pm
I do not understand why is this still like that! It is only to change the name - nothing else.. :( F**ckin..
ivden
Tue Mar 14, 2023 9:07 pm
But how did you manage to install The dude onto routerOS v7? There is no dude package for v7.
holvoetn
Tue Mar 14, 2023 9:10 pm
ivden
Tue Mar 14, 2023 9:16 pm
Yeah, finally figure it out I have to download all-packages archive. Installation docs are a bit misleading.
MasteRTriX
Wed Aug 16, 2023 10:31 pm
both 7.9 and 7.11 issue still present
MagnAxiom
Thu Aug 24, 2023 4:46 pm
Same situation in Aug 24, 2023, version 7.11
stevedavis
Fri Aug 25, 2023 1:03 pm
Likewise still an issue.
Is there a timeline for a fix for this? Is it specific to particular packages, or is it all packages?
pe1chl
Fri Aug 25, 2023 1:50 pm
The Dude is no longer being developed. I don't expect the situation to change. When you want to keep using it, deploy your own scripting solution for upgrades.
ubikrotik
Sun Jan 21, 2024 6:07 am
still the same. unable to mass upgrade our routers with the dude. any update guys? @normis
hknet
Tue Feb 20, 2024 7:48 am
So - finally we also do see this issue as we tried upgrading v7.13.x recently using the Dude.
As we now have devices that simply need ROS v7 to work - this is getting an issue as our emergency upgrade plans in case of a serious security issue with ROS is currently to go to the dude and upgrade all devices needing upgrades... The prospect of having to do this manually or using another scripting tool is not exactly what we had envisioned for emergency processes.
As it was claimed in this thread that the Dude is kind of EOL - is this confirmed by Mikrotik?
Any advice on ROS emergency upgrade procedures would be nice.
Regards, hk
Users browsing this forum: No registered users and 2 guests
