Does MikroTik RouterOS 6.47 support 2 Trunks on the same physical Router (CCR1009 and/or RB4011)?
I am attempting to setup a BASIC router with 2 Trunk ports to two different bridges.
TOPOLOGY
Interface E2 ----- Trunk1----**Bridge1 ** port 2---------Vlan 10 ----PC1
port 3---------Vlan 20 ----PC2
Router
Interface E3 ----- Trunk2----**Bridge2 ** port 2----------Vlan 10 ----PC3
port 3----------Vlan 20 ----PC4
PROBLEM: I cannot assign Vlan10 to 2 different interfaces. If I give the second Vlan10 a different name I can assign to E3 but traffic fails.
Anyone know if this is possible or I have run up against another limitation of RouterOS? Packet sniffer shows ICMP traffic is
AND YES I have read the wiki docs and most other publicly available docs and still reading them. The docs show daisy chaining devices and of course daisy chaining your devices creates a serious single point of failure - Yikeeeeesssss
I am really hoping there were some real MikroTik experts out there just waiting for a real challenge
What I see:
Packet Captured on Bridge1 E2 Tx
PC1 ICMP packets are egressing Bridge1 E2 with .1q tag as VLAN ID 10. This is correct!
Packet captured on Bridge1 E2 Rx
Return Packets from the Router1 on E2 - Destination host unreachable from 192.168.0.1
Router VLan30 ARPs (broadcast) for 192.168.0.33 MAC address
From PC1, successful pings to VLan10 192.168.0.1, vlan20 192.168.0.17 and Vlan30 192.168.0.33.
Router1 Config
/interface bridge add name=BR-A vlan-filtering=yes
/interface vlan
add interface=E2 name=E2-VL10 vlan-id=10
add interface=E3 name=E3-VL10 vlan-id=10
add interface=E2 name=E2-VL20 vlan-id=20
add interface=E3 name=E3-VL20 vlan-id=20
add interface=E2 name=MGT-E2-VL30 vlan-id=30
add interface=E3 name=MGT-E3-VL30 vlan-id=30
add bridge=BR-A interface=E2
add bridge=BR-A interface=E3
/interface bridge vlan
add bridge=BR-A tagged=E2,E3 vlan-ids=10
add bridge=BR-A tagged=E2,E3 vlan-ids=20
add bridge=BR-A tagged=E2,E3 untagged=BR-A vlan-ids=30
add address=192.168.0.1/28 interface=E2-VL10 network=192.168.0.0
add address=192.168.0.17/28 interface=E2-VL20 network=192.168.0.16
add address=192.168.0.33/28 interface=MGT_E2-VL30 network=192.168.0.32
add address=192.168.0.14/28 interface=E2-VL10 network=192.168.0.0
/system identity set name=Router1
Thank you
Frank
