10 years of MikroTik RouterOS scripting, and my .rsc editor is still Notepad. What do you use?
tldr: I still edit .rsc in a plain text editor. My typos show up at runtime.
Curious what everyone else runs.
10+ years of MikroTik RouterOS here. Scripts on more routers than I can count.
My setup:
  1. text editor on one monitor
  2. terminal on the other
  3. copy-paste
  4. production tells me about the typo
Not that nothing exists. One of the VS Code extensions was my daily driver for years โ€” respect to the author. Tried the newer ones too.
Next to Python it still feels a generation behind. Or my expectations are too high. That's why I'm asking.
So:
  1. What do you write your scripts in? Not what is "proper" โ€” what you really use
  2. Happy with it?
  3. What bites you most often?
For me it's a mistyped property name. Often deprecated things, especially the recent ACME and certificate related drifts; Does nothing, says nothing.
p.s.: Undeclared functions/variables and wrong scoping is another daily pain..
Nikita
  • What do you actually write your RouterOS scripts in?
  • Winbox / WebFig terminal window
  • Notepad++ / Sublime / another text editor with a highlighter
  • VS Code with one of the RouterOS extensions from the Marketplace
  • VS Code as plain text
  • vim / nano over SSH
  • I write it straight on the router and pray
  • I avoid scripting whenever I can
0 voters
VSCode with this extension for color : https://marketplace.visualstudio.com/items?itemName=devMike.mikrotik-routeros-script
And i use a lab router for test it, by remove/add with ssh.
i use built in routeros editor and notepad++ with routeros coloring
I use Notepade++
btw, @tarikin, Your work is outstanding <> I am a long time admirer ...
Macromedia HomeSite+ 5.5 (year 2003) on big script
Classic Notepad (Windows 10, not the shi~~y from Windows 11) for "on the fly" edit
@dang21000 that's the exact one I meant. My daily driver from 2018 to 2025.
The lab router part is the interesting bit. We keep spare hardware to catch typos.
@rextended HomeSite+ 5.5 from 2003. Best answer in this thread.
Serious question: what does it give you on big scripts that the modern ones don't?
@biki73 @mozerd thanks. Notepad++ keeps coming up.
So far everything here colors the text. Nothing checks it.
VS Code + RouterOS LSP
@mrz fair โ€” that one actually checks. Tried it when it came out. Solid work by Amm0.
Since you run it: does it catch deprecated properties too, or syntax only?
Deprecations are my worst one โ†’ the new ACME and recent certificates section drifts especially.
My problem is my setup, not the tool. Half my editing happens over screen sharing. Customer's desktop, customer's network. Asking for router credentials there is not always a conversation I can have. So I end up back in a plain editor.
built in editor does check and autocomplete, only thing it's missing is save without quit.
Yeap, @biki73 true โ€” the built-in one checks. It is the router, after all.
Save without quit is a small thing that costs a lot.
So everything that checks needs the router. On a customer's desktop I have neither.
Anything out there that checks a script offline? I have not found one.
Sublime Text + @Kentzo MikroTikScript GitHub - Kentzo/MikrotikScript: Syntax highlighting and completions for the Mikrotik Scripting language for the Sublime Text editor ยท GitHub
It's like Winbox 3 compared to Winbox 4...
3 works, 4 is nice (maybe)...
@Simonej right, that is the one from the pinned thread. Colors and completions, no checking.
@rextended fair, and that is the test. Winbox 4 is a repaint, and a repaint is not worth relearning anything for.
What did HomeSite give you in 2003 that made it worth learning then?
2003 because that's the latest version...
I was already using HomeSite 4 on 1998 to create websites in .HTML and .ASP,
when back then there weren't many reliable tools other than your own head and writing the HTML directly...
Then I never switched to anything else, because the HomeSite text editor is fantastic, from my point of view.
When the need arose in 2007 to work with RouterOS and scripts, well, obviously I always used that.
I use vim for pretty much everything and love it for RouterOS code highlighting.
@rextended so you brought it with you from 1998 โ€” not picked for RouterOS at all. Did not expect that. "Your own head" is still the best checker on that list.
@ghostinthenet which highlighting file do you use for vim? Been meaning to set that up properly.
I've been happy with the built-in syntax highlighting. If someone wants to recommend a better file, I'll give it a try.
Still you have voted for "VS Code with one of the RouterOS extensions from the Marketplace' in your own poll. :joy:
I'd say that keyboard and mouse navigation is painful there. Alt/option+arrow word navigation inside large script of 100+ is a UX nightmare. Especially after claude cli editors; I've sent feature request to winbox4 developers some months ago for a good luck, but i'm not even hoping anymore ^_*
I'm spoiled to have vscode plugin for AstroJS web framework with built-in LSP, this accelerates daily routines; RouterOS grammar however feels like a 007 top secret;
More to say: the scripting documentation is so tough, inconsistent and often contradictive - even for certified trainers, so i had to squeeze all the juice from official documentation, my own daily experience and hundreds of hours of experiments into GitHub - tarikin/routeros-7-llm-safe-reference: Verified RouterOS 7 Standard Library for AI Agents. Hallucination-free MikroTik NetDevOps grounding context, RAG truth anchors, and prompt engineering. (v7.21+) ยท GitHub ... But that is another story;
That was a bit of self-irony, i'm on macOS, notepad is unsupported here ))
