Could you please suggest me the 10g Switch?Having more than 10-16 port have 10g .
high end configuration
Susil
As you posted in a MikroTik Forum, you won’t get any recommendations for MikroTik Gear b/c there is no MikroTik switch model with more than 16 10G ports.
Then, it depends on your definition of “high end configuration” and your budget.
I just deployed a couple of fully populated Cisco Nexus 36180YC-R… And they’re performing great in this scenario. If that fits your expectations and budget…
-Chris
