I am using dude version 6.36.2.
10Gbps interface link is showing 4.29Gbps speed on dude.
Kindly guide me.
Kindly guide me.
Hello, vijaykumaryadav4u!
Maybe topic, Problem SNMP speed interface, will explain something.
Thank you!
Thanks for the information but my problem not solved.
When Dude will support 64bit counters.
Hello, that seems to be an issue related to SNMP, have you try to configure that link’s mastering type to RouterOS instead of SNMP?? If yuu have lot’s of Mikrotiks been monitoring by Dude, it’s a most accurate choice to connect them via RouterOS instead of SNMP, you’ll need to create a new user (just for security, with read only & dude policies)
Any update on 64-bit counters support for Dude?
We can safely assume that monitoring 10Gbps links on SwitchOS with the Dude will not provide good results due to the 32bits issue, right?
+1
I see the same problem for a long time at The Dude…
Same Here
Please, update the Dude with 64bit counters
Same Here
