Thanks @anav, @biomesh
CPU in normal behavior using the internet causes very low CPU load <10% even streaming videos but with only 300MB.
SFP+ Port1 is configured as "IN"-Port / WAN connected to the ISP router using a 10G transceiver "SFP-10G-T" to have the possibility to update somewhen in the future when maybe my ISP provides 10G.
I would be confused if it's a 10G to 1G issue as I have exactly the same behavior using a 1G SFP transceiver "SFP-GB-GE-T" in SFP+ Port1 instead of the 10G transceiver.
Here the export - hope this brings some clarity. Appreciate your help:
dec/30/2021 15:20:17 by RouterOS 7.1.1
software id = 0QAH-AZR1
model = CRS309-1G-8S+
serial number =
add admin-mac=######### auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] advertise="10M-half,10M-full,100M-half,100M-f
ull,1000M-half,1000M-full,10000M-full,2500M-full,5000M-full"
set [ find default-name=sfp-sfpplus1 ] advertise="10M-half,10M-full,100M-half,
100M-full,1000M-half,1000M-full,10000M-full,2500M-full,5000M-full" name=
sfp-sfpplus1-ether-10G
set [ find default-name=sfp-sfpplus2 ] advertise="10M-half,10M-full,100M-half,
auto-negotiation=no name=sfp-sfpplus2-fiber-LCAPCSM-1G
set [ find default-name=sfp-sfpplus3 ] auto-negotiation=no name=
sfp-sfpplus3-ether-1G
set [ find default-name=sfp-sfpplus4 ] disabled=yes
set [ find default-name=sfp-sfpplus5 ] advertise="10M-half,10M-full,100M-half,
auto-negotiation=no name=sfp-sfpplus5-ether-1G
set [ find default-name=sfp-sfpplus6 ] auto-negotiation=no disabled=yes
set [ find default-name=sfp-sfpplus7 ] disabled=yes
set [ find default-name=sfp-sfpplus8 ] advertise="10M-half,10M-full,100M-half,
auto-negotiation=no name=sfp-sfpplus8-fiber-LCUPCMM-1G
add name=WAN
add name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
add interface=bridge name=dhcp2 relay=192.168.88.1
add name=dhcp ranges=192.168.88.100-192.168.88.254
add address-pool=dhcp interface=bridge name=dhcp1
/port
set 0 name=serial0
add bridge=bridge comment=defconf ingress-filtering=no interface=ether1
add bridge=bridge comment=defconf disabled=yes ingress-filtering=no
interface=sfp-sfpplus1-ether-10G
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus4
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus6
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus7
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set disable-ipv6=yes
add interface=sfp-sfpplus2-fiber-LCAPCSM-1G list=LAN
add interface=sfp-sfpplus3-ether-1G list=LAN
add interface=sfp-sfpplus4 list=LAN
add interface=sfp-sfpplus5-ether-1G list=LAN
add interface=sfp-sfpplus6 list=LAN
add interface=sfp-sfpplus7 list=LAN
add interface=sfp-sfpplus8-fiber-LCUPCMM-1G list=LAN
add interface=sfp-sfpplus1-ether-10G list=WAN
add interface=bridge list=LAN
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
add address=192.168.1.100/24 interface=sfp-sfpplus1-ether-10G network=
192.168.1.0
/ip dhcp-client
add disabled=yes interface=sfp-sfpplus1-ether-10G
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
set servers=1.1.1.1,1.0.0.1,8.8.8.8,8.8.4.4
add action=fasttrack-connection chain=forward comment=
"FastTrack DNS connection for TCP to make Internet/DNS faster" dst-port=
53 hw-offload=yes protocol=tcp
"FastTrack DNS connection for UDP to make Internet/DNS faster" dst-port=
53 hw-offload=yes protocol=udp
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.1.1
/ip service
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Zurich
/system routerboard settings
set boot-os=router-os
/system swos
set allow-from-ports=p1,p2,p3,p4,p5,p6,p7,p8,p9 identity=MikroTik
/tool graphing interface
add
