Why mt 2.8.26 works better on 2,4 ghz than mt 2.9.xx ?
Can any explain that ?
Porblems 2.9:
on prism - 20 clients connected and ping high (200 pps)
on athreos - 20 cli … this same.
on 2.8 : -
40 clients on prism and all ok (400 pps)
athreos - not tested.
I’ve 5 rb 500 and i cannot swich it to 2.8 (not supported)
i tested all - cards, pigtails, anthenas and nothing still bad perfomance
typical config of wlan on 2.9
1 R name="wlan1" mtu=1500 mac-address=xx... arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name="xx..." mode=ap-bridge ssid="..."
area="" frequency-mode=regulatory-domain country=poland antenna-gain=0
frequency=2457 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power=24 tx-power-mode=all-rates-fixed
noise-floor-threshold=default periodic-calibration=disabled
periodic-calibration-interval=60 burst-time=disabled dfs-mode=none
antenna-mode=ant-b wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=no
default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=long compression=no allow-sharedkey=no
FIx it …
could u tell me when will work or i must sell my rb’s ?
