Yesterday Evening i was going through the SFP Modules Specs Sheet and Founf that SFP Family Modules (NOT SFP+) has following DATA RATES which is 1.25G, 2.5G & 4.25G on Optical SFP Modules.
My Doubt is Can i use 2.5G or 4.25G Optical SFP Module in my SFP Port of My CCR1036-12G-4S?
Have anyone every Tried using 2.5G SFP Module is Mikrotik SFP Cage???
Appriciate if some one throw some light in to this!!!
Those PHY rates don’t directly apply to ethernet as L2 protocol (they are used for CPRI, FC, Sonet, etc.). And Mikrotiks only talk ethernet over SFP. AFAIK line rates of 2.5 Gbps and 5Gbps on ethernet are only available on SFP+ modules. And according to my understanding, Mikrotik only supports 1Gbps data rate through SFP cages and 10Gbps data rate through SFP+ cages which limits usable line rates used through certain cage type (line rate can not exceed “cage rate”).
I went through this Thread but now ROS is having Negotiations 2.5G and 5G in its setting. Any chance that you have tried 2.5G SFP on Normal SFp cage of mikrotik and Set Manual Negotiation for that interface???
After the tests in the thread I linked, I next tried forcing the autonegotation speeds to 1G, and that allowed both speeds of FiberChannel SFP to work in the hEX. That’s 4.25 and 2.125 Gbit/sec, not this new-fangled 2.5 Gbit/sec stuff, but I would guess the principle is the same.
I would not expect you to get 2.5 Gbit/sec in an SFP port. You might make it work at 1G.
What might work is a 2.5 Gbit/sec module in an SFP+ port. I do believe that’s the intent of this new RouterOS feature you’re talking about, to allow devices like the RB5009 to do 2.5 on both its fast copper port and its fiber port.
This Surely Requires a Test.
I’ve done what I can with the equipment I have, none of which is a CCR1036.
