Thanks for taking a look. My configs are below.
Using the diagram above this is how wired:
switch sfp-sfpplus1 → router1 sfp-sfpplus1
switch ether6 → router2 ether2
router1 ether1 → ISP1
router2 ether1 → ISP2
workstation → ether17 (when testing vlan20)
workstation → ether19 (when testing default vlan)
Desired Behavior:
If router1 fails, then use router2: uses VRRP. PASS with both default vlan and vlan20. VRRP .254 def gateway must be used.
Any machine to directly use router1 or router2 (.1 or .2) gateways directly. PASS. I need this for my monitoring code to verify health of network as well as using vtrunkd.
if ISP1 fails, then route out router2 AND support for PBR using mangle and address lists: uses routing rules and filters, PASS with default vlan IFF default gateway is NOT VRRP. FAIL with vlan20.
If I dump router2, put ISP2 on router1 ether2, and change that to be marked as isp2, then everything in #3 works as expected (this is my current running solution on a different router; the configs below are in a lab getting ready for deployment). OTOH, I do not have a 2nd router or VRRP. Not a huge issue, but I figured why not? since I’ll have a 2nd rack mount router. The HeX playing the role of router2 is just a place holder.
Other things I have tried:
- disable fasttrack. I’ve had issues with fasttrack and vlans in the past.
- Connect ether3 to ether3 of the routers and use a different subnet to route from 1 to 2.
Switch:
# sep/10/2017 08:19:40 by RouterOS 6.41rc26
# software id = 4HJ8-GWWB
# model = CRS326-24G-2S+
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no igmp-snooping=no name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=vlan20 vlan-id=20
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add bridge=bridge1 interface=ether13
add bridge=bridge1 interface=ether14
add bridge=bridge1 interface=ether15
add bridge=bridge1 interface=ether16
add bridge=bridge1 interface=ether17 pvid=20
add bridge=bridge1 interface=ether18
add bridge=bridge1 interface=ether19
add bridge=bridge1 interface=ether20
add bridge=bridge1 interface=ether21
add bridge=bridge1 interface=ether22
add bridge=bridge1 interface=ether23
add bridge=bridge1 interface=ether24
add bridge=bridge1 interface=sfp-sfpplus1
add bridge=bridge1 interface=sfp-sfpplus2
/interface bridge vlan
add bridge=bridge1 tagged=sfp-sfpplus1,ether6 untagged=ether17 vlan-ids=20-30
add address=172.16.1.1/16 interface=bridge1 network=172.16.0.0
add address=172.20.1.1/16 interface=vlan20 network=172.20.0.0
add distance=1 gateway=172.16.0.1
/system identity
set name=switch
/system package update
set channel=release-candidate
/system routerboard settings
set boot-os=router-os
router1:
add fast-forward=no name=bridge1
/interface vrrp
add interface=sfp-sfpplus1 name=vrrp1 priority=254
/interface vlan
add interface=sfp-sfpplus1 name=vlan20 vlan-id=20
/interface vrrp
add interface=vlan20 name=vrrp20 priority=254 vrid=20
add name=external
/routing bgp instance
set default as=100 disabled=yes
add bridge=bridge1 interface=combo1
add interface=ether1 list=external
add disabled=yes interface=ether2 list=external
add address=172.16.0.254 interface=vrrp1 network=172.16.0.254
add address=172.16.0.1/16 interface=sfp-sfpplus1 network=172.16.0.0
add address=172.20.0.1/16 interface=vlan20 network=172.20.0.0
add address=172.20.0.254 interface=vrrp20 network=172.20.0.254
/ip dhcp-client
add disabled=no interface=ether1
/ip firewall address-list
add address=172.20.1.10 comment="preferisp2, failover to isp1" disabled=yes list=preferisp2
add address=172.20.1.10 comment="only out isp1" disabled=yes list=onlyisp1
add address=172.20.1.10 comment="preferisp1, failover to isp2" disabled=yes list=preferisp1
add address=172.20.1.10 comment="only out isp2" disabled=yes list=onlyisp2
add address=172.16.1.10 comment="preferisp2, failover to isp1" disabled=yes list=preferisp2
add address=172.16.1.10 comment="only out isp1" disabled=yes list=onlyisp1
add address=172.16.1.10 comment="preferisp1, failover to isp2" disabled=yes list=preferisp1
add address=172.16.1.10 comment="only out isp2" disabled=yes list=onlyisp2
add action=accept chain=input comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=input comment="drop all from WAN, external interface list" in-interface-list=external
add action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="drop all from WAN not DSTNATed, external interface list" connection-nat-state=\
!dstnat connection-state=new in-interface-list=external
/ip firewall mangle
add action=mark-routing chain=prerouting comment="prefer isp1, failover to isp2 (default)" new-routing-mark=preferisp1 \
passthrough=yes
add action=mark-routing chain=prerouting comment="only out isp1 (onlyisp1 address list)" new-routing-mark=onlyisp1 \
passthrough=yes src-address-list=onlyisp1
add action=mark-routing chain=prerouting comment="prefer isp2, failover to isp1 (preferisp2 address list)" disabled=\
yes new-routing-mark=preferisp2 passthrough=no src-address-list=preferisp2
add action=mark-routing chain=prerouting comment="only out isp2 (onlyisp2 address list)" new-routing-mark=onlyisp2 \
passthrough=yes src-address-list=onlyisp2
add action=masquerade chain=srcnat comment="external interface list" out-interface-list=external
add check-gateway=ping distance=2 gateway=172.16.0.2 routing-mark=isp2
/ip route rule
add comment="isp1 only / disallow failover" routing-mark=onlyisp1 table=main
add routing-mark=onlyisp1 table=isp1
add action=unreachable routing-mark=onlyisp1
add comment="prefer isp1 but allow failover to isp2" routing-mark=preferisp1 table=main
add routing-mark=preferisp1 table=isp1
add routing-mark=preferisp1 table=isp2
add comment="isp2 only / disallow failover" routing-mark=onlyisp2 table=main
add routing-mark=onlyisp2 table=isp2
add action=unreachable routing-mark=onlyisp2
add comment="prefer isp2 but allow failover" disabled=yes routing-mark=preferisp2 table=main
add disabled=yes routing-mark=preferisp2 table=isp2
add disabled=yes routing-mark=preferisp2 table=isp1
add comment="unmarked traffic" table=main
add table=isp1
add table=isp2
/lcd
set backlight-timeout=never color-scheme=dark default-screen=interfaces
/lcd interface
set sfp-sfpplus1 disabled=yes
set combo1 disabled=yes
set ether2 disabled=yes
set ether3 disabled=yes
set ether4 disabled=yes
set ether5 disabled=yes
set ether6 disabled=yes
set ether7 disabled=yes
/routing bgp peer
add disabled=yes in-filter=from-router2 name=router2 remote-address=172.16.0.2 remote-as=100
/routing filter
add chain=dynamic-in distance=1 prefix=0.0.0.0 prefix-length=0 set-check-gateway=ping set-routing-mark=isp1
add bgp-local-pref=100 chain=from-router2 disabled=yes set-check-gateway=ping set-distance=3 set-routing-mark=isp3
/system identity
set name=router1
router2:
# sep/10/2017 08:47:41 by RouterOS 6.41rc26
# software id = 8CFI-AN74
# model = 960PGS
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf fast-forward=no igmp-snooping=no name=bridge1
set [ find default-name=ether2 ] poe-out=off
set [ find default-name=ether3 ] poe-out=off
/interface vrrp
add interface=ether2 name=vrrp1
/ip neighbor discovery
set ether1 discover=no
/interface vlan
add interface=ether2 name=vlan20 vlan-id=20
/interface vrrp
add interface=vlan20 name=vrrp20 vrid=20
/ip hotspot profile
/port
set 0 baud-rate=115200 name=usb1
set default as=100 client-to-client-reflection=no disabled=yes redistribute-connected=yes
add bridge=bridge1 comment=defconf disabled=yes interface=ether2
add bridge=bridge1 comment=defconf hw=no interface=sfp1
add bridge=bridge1 disabled=yes interface=ether3
add bridge=bridge1 disabled=yes tagged=ether2 vlan-ids=20
add address=172.16.0.2/16 comment=defconf interface=ether2 network=172.16.0.0
add address=172.20.0.2/16 interface=vlan20 network=172.20.0.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=ether1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
connection-state=new in-interface=ether1
/ip firewall mangle
add action=mark-routing chain=prerouting comment="only out isp2 (onlyisp2 address list)" disabled=yes \
new-routing-mark=onlyisp2 passthrough=yes src-address-list=onlyisp2
add action=mark-routing chain=prerouting comment="prefer isp2, failover to isp1 (default)" disabled=yes \
new-routing-mark=preferisp2 passthrough=yes
add action=mark-routing chain=prerouting comment="prefer isp1, failover to isp2 (preferisp1 address list)" disabled=\
yes new-routing-mark=preferisp1 passthrough=yes src-address-list=preferisp1
add action=mark-routing chain=prerouting comment="only out isp1 (onlyisp1 address list)" disabled=yes \
new-routing-mark=onlyisp1 src-address-list=onlyisp1
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=ether1
/ip route rule
add comment="prefer isp2 but allow failover to isp1" disabled=yes routing-mark=preferisp2 table=main
add comment="isp1 only / disallow failover" disabled=yes routing-mark=onlyisp1 table=main
add disabled=yes routing-mark=onlyisp1 table=isp1
add action=unreachable disabled=yes routing-mark=onlyisp1
add comment="prefer isp1 but allow failover" disabled=yes routing-mark=preferisp1 table=main
add disabled=yes routing-mark=preferisp1 table=isp1
add disabled=yes routing-mark=preferisp1 table=isp2
add table=isp2
add disabled=yes table=isp1
/ip smb shares
set [ find default=yes ] directory=/pub
/routing bgp peer
add disabled=yes name=router1 out-filter=to_router1 remote-address=172.16.0.1 remote-as=100
/routing filter
add chain=dynamic-in distance=1 prefix=0.0.0.0 prefix-length=0 set-check-gateway=ping set-routing-mark=isp2
add action=discard chain=to_router1 disabled=yes prefix=10.0.0.0/24
add action=discard chain=to_router1 disabled=yes prefix=172.16.0.0/16
add action=discard chain=to_router1 disabled=yes prefix=172.20.0.0/16
/system identity
set name=router2
/tool graphing interface
add
/tool mac-server
/tool mac-server mac-winbox
