Hello
i have a problem configuring a router to use load balance with 2 ISP and recursive routes
this conf doesn't do load balance only fail-over how can i fix it ?
any ideas ?
this is my conf :
model = CCR1009-7G-1C-1S+
add name=LAN_Management
set [ find default-name=combo1 ] disabled=yes
set [ find default-name=ether1 ] name=eth1_ISP1 speed=100Mbps
set [ find default-name=ether2 ] name=eth1_ISP2 speed=100Mbps
set [ find default-name=ether3 ] name=eth3_LAN1 speed=100Mbps
set [ find default-name=ether4 ] name=eth4_LAN2 speed=100Mbps
set [ find default-name=ether7 ] name=eth7_LAN3 speed=100Mbps
set [ find default-name=ether5 ] disabled=yes speed=100Mbps
set [ find default-name=ether6 ] speed=100Mbps
set [ find default-name=sfp-sfpplus1 ] advertise=
10M-full,100M-full,1000M-full disabled=yes
/interface vlan
add interface=eth4_LAN2 name=VL110_P vlan-id=110
add interface=eth3_LAN1 name=VL120_M vlan-id=120
add interface=eth3_LAN1 name=VL130_PERS vlan-id=130
add name=WAN
add name=LAN
add bridge=LAN_Management interface=eth7_LAN3
add bridge=LAN_Management interface=ether6
/interface l2tp-server server
set enabled=yes ipsec-secret=testvpn use-ipsec=yes
add address=192.168.0.1/24 interface=VL130_PERS network=192.168.0.0
add address=10.0.0.1/22 interface=VL110_P network=10.0.0.0
add address=86.34.186.154/29 interface=eth1_ISP1 network=86.34.186.152
add address=185.132.173.29/25 interface=eth1_ISP2 network=185.132.173.0
add address=172.16.172.1/24 interface=eth7_LAN3 network=172.16.172.0
add address=192.168.2.1/24 interface=VL120_M network=192.168.2.0
set servers=1.1.1.1,8.8.8.8
/ip firewall address-list
add address=192.168.0.0/24 list=LAN
add address=172.16.172.0/24 list=LAN
add address=192.168.2.0/24 list=LAN
add address=10.0.0.0/22 list=LAN
add address=86.34.186.0/24 list=Connected
add address=185.132.173.0/24 list=Connected
add address=192.168.0.0/24 list=Connected
add address=172.16.172.0/24 list=Connected
add address=192.168.2.0/24 list=Connected
add address=10.0.0.0/22 list=Connected
add address=192.168.89.0/24 list=Connected
add address=192.168.89.0/24 list=LAN
add action=accept chain=input comment="accept snmp de la 172.16.172.22"
dst-port=161 protocol=udp src-address=172.16.172.22
add action=drop chain=input comment="drop snmp from all" dst-port=161
protocol=udp
/ip firewall mangle
add action=mark-routing chain=prerouting connection-mark=RTL>LAN
new-routing-mark=ISP1 passthrough=yes src-address-list=LAN
new-routing-mark=ISP2 passthrough=yes src-address-list=LAN
add action=mark-connection chain=input comment=WAN>ROS connection-mark=
no-mark in-interface=eth1_ISP1 new-connection-mark=RTL>ROS
passthrough=yes
add action=mark-connection chain=input connection-mark=no-mark in-interface=
eth1_ISP2 new-connection-mark=CBS>ROS passthrough=yes
add action=accept chain=prerouting comment="Connected networks -> accept"
dst-address-list=Connected src-address-list=Connected
add action=mark-routing chain=output connection-mark=RTL>ROS
add action=mark-routing chain=output connection-mark=CBS>ROS
add action=mark-connection chain=forward comment=WAN>LAN connection-mark=
no-mark in-interface=eth1_ISP1 new-connection-mark=RTL>LAN
passthrough=yes
add action=mark-connection chain=forward connection-mark=no-mark
in-interface=eth1_ISP2 new-connection-mark=CBS>LAN passthrough=yes
add action=mark-routing chain=prerouting connection-mark=CBS>LAN
add action=mark-connection chain=prerouting comment="LAN > WAN"
connection-mark=no-mark dst-address-list=!Connected dst-address-type=
!local new-connection-mark=LAN>WAN passthrough=yes src-address-list=LAN
add action=mark-routing chain=prerouting comment="Load Balancehere"
connection-mark=LAN>WAN new-routing-mark=ISP1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=LAN>WAN
"Stick connections after this" connection-mark=LAN>WAN
new-connection-mark=Sticky_ISP1 passthrough=yes routing-mark=ISP1
add action=mark-connection chain=prerouting connection-mark=LAN>WAN
new-connection-mark=Sticky_ISP2 passthrough=yes routing-mark=ISP2
add action=mark-routing chain=prerouting connection-mark=Sticky_ISP1
add action=mark-routing chain=prerouting connection-mark=Sticky_ISP2
add action=dst-nat chain=dstnat dst-port=80 in-interface=eth1_ISP1
protocol=tcp to-addresses=192.168.0.254 to-ports=80
add action=dst-nat chain=dstnat dst-port=443 in-interface=eth1_ISP1
protocol=tcp to-addresses=192.168.0.254 to-ports=443
add action=dst-nat chain=dstnat dst-port=554 in-interface=eth1_ISP1
protocol=tcp to-addresses=192.168.0.19 to-ports=554
add action=dst-nat chain=dstnat dst-port=555 in-interface=eth1_ISP1
protocol=tcp to-addresses=192.168.0.20 to-ports=555
add action=dst-nat chain=dstnat dst-port=8000 in-interface=eth1_ISP1
protocol=tcp to-addresses=192.168.0.19 to-ports=8000
add action=dst-nat chain=dstnat dst-port=8001 in-interface=eth1_ISP1
protocol=tcp to-addresses=192.168.0.20 to-ports=8001
add action=dst-nat chain=dstnat dst-port=8003 in-interface=eth1_ISP1
protocol=tcp to-addresses=192.168.0.75 to-ports=8003
add action=dst-nat chain=dstnat dst-port=8083 in-interface=eth1_ISP1
protocol=tcp to-addresses=192.168.0.19 to-ports=8083
add action=dst-nat chain=dstnat dst-port=8084 in-interface=eth1_ISP1
protocol=tcp to-addresses=192.168.0.20 to-ports=8084
add action=dst-nat chain=dstnat dst-port=8103 in-interface=eth1_ISP1
protocol=tcp to-addresses=192.168.0.236 to-ports=8103
add action=dst-nat chain=dstnat dst-port=8185 in-interface=eth1_ISP1
protocol=tcp to-addresses=192.168.0.236 to-ports=8185
add action=dst-nat chain=dstnat dst-port=8881 in-interface=eth1_ISP1
protocol=tcp to-addresses=192.168.0.254 to-ports=8881
add action=dst-nat chain=dstnat comment="nms monitor" dst-port=8080
in-interface=eth1_ISP1 protocol=tcp to-addresses=192.168.0.7
to-ports=80
add action=dst-nat chain=dstnat disabled=yes dst-port=8307 in-interface=
eth1_ISP1 protocol=tcp to-addresses=172.16.172.101 to-ports=8307
add action=masquerade chain=srcnat out-interface=eth1_ISP1
add action=masquerade chain=srcnat out-interface=eth1_ISP2
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=
192.168.89.0/24
add action=dst-nat chain=dstnat disabled=yes dst-address-list="" dst-port=
35265 in-interface=eth1_ISP1 log=yes protocol=tcp to-addresses=
172.16.172.2 to-ports=23
add distance=1 gateway=10.1.1.1 routing-mark=ISP1
add distance=2 gateway=10.2.2.2 routing-mark=ISP1
add distance=1 gateway=10.2.2.2 routing-mark=ISP2
add distance=2 gateway=10.1.1.1 routing-mark=ISP2
add distance=1 dst-address=1.0.0.1/32 gateway=185.132.173.x scope=10
add distance=1 dst-address=1.1.1.1/32 gateway=86.34.186.x scope=10
add distance=1 dst-address=8.8.4.4/32 gateway=185.132.173.x scope=10
add distance=1 dst-address=8.8.8.8/32 gateway=86.34.186.x scope=10
add check-gateway=ping distance=1 dst-address=10.1.1.1/32 gateway=8.8.8.8
scope=10
add check-gateway=ping distance=1 dst-address=10.1.1.1/32 gateway=1.1.1.1
scope=10
add check-gateway=ping distance=1 dst-address=10.2.2.2/32 gateway=1.0.0.1
scope=10
add check-gateway=ping distance=1 dst-address=10.2.2.2/32 gateway=8.8.4.4
scope=10
