Greetings! I have run onto some problems while trying to do the following:
I have got 2 connections SL 6 Mb and 10 mb - i want to seperate them for special Tasks
For example: 6 Mb would be used for pages WWW, VoIP , etc… and 10 mb for Downloading via WWW , torrents , cutting user’s transfer , and i would like to add Web proxy , DHCP server in here
I want my Network in Mikrotik to look like this : 2x SL ← 2X WAN → < – NAT–> <..queue tree seperated for Special tasks and Cutting transfer → < - bridge, which would consist of 6x Lan and 3x Wlan , both of them draining IP from the same DHCP server via MAC, and having THE SAME IP adress → users of network
I would be very grateful if You could attach any exmaples of such Configurations.
INFORMATIONS:
Currently I am working on a RB493G Routerboard, i bought it few days ago. I havent connected it to 2x SL yet, only WAN1 is connected to the normal router , which has DHCP and internet connection via WiFi
SLs use " dynamic" IP
Additional Question:
After starting up Mikrotik 493G , it doesnt seem to be looking for ANY DHCP adress, nor it is giving an reaction. It keeps on" searching" until i Restart it. Than everything is OK.
I am attaching my current Trials of Configurating it
ROUTE:
0 A S dst-address=192.168.2.1/32 gateway=WAN1 gateway-status=WAN1 reachable
check-gateway=ping distance=1 scope=30 target-scope=10
routing-mark=DSL1
1 S dst-address=192.168.2.1/32 gateway=WAN2 gateway-status=WAN2 unreachable
routing-mark=DSL2
2 ADS dst-address=0.0.0.0/0 gateway=192.168.1.1
gateway-status=192.168.1.1 reachable WAN1 distance=0 scope=30
target-scope=10 vrf-interface=WAN1
3 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.32 gateway=WAN1
gateway-status=WAN1 reachable distance=0 scope=10
4 ADC dst-address=192.168.2.0/24 pref-src=192.168.2.1 gateway=PUBLIC<—>LOCAL
gateway-status=PUBLIC<—>LOCAL reachable distance=0 scope=10
5 ADC dst-address=192.168.88.0/24 pref-src=192.168.88.1 gateway=etherPOE
gateway-status=etherPOE unreachable distance=0 scope=200
DHCP client:
0 interface=WAN1 add-default-route=yes default-route-distance=0
use-peer-dns=yes use-peer-ntp=yes status=bound address=192.168.1.32/24
gateway=192.168.1.1 dhcp-server=192.168.1.1 primary-dns=192.168.1.1
expires-after=2d17h23m53s
1 interface=WAN2 add-default-route=yes default-route-distance=0
use-peer-dns=yes use-peer-ntp=yes status=searching…
DHCP server
0 name=“dhcp1” interface=PUBLIC<—>LOCAL lease-time=1d
address-pool=dhcp_pool2 bootp-support=static
authoritative=after-2sec-delay
BRIDGE
0 R name=“PUBLIC<—>LOCAL” mtu=1500 l2mtu=1524 arp=enabled
mac-address=00:0C:42:A9:16:D2 protocol-mode=none priority=0x8000
auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s
forward-delay=15s transmit-hold-count=6 ageing-time=5m
BRIDGE ports
INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 ether8 PUBLIC<—>LOCAL 0x80 10 none
1 I ether3 PUBLIC<—>LOCAL 0x80 10 none
2 I ether4 PUBLIC<—>LOCAL 0x80 10 none
3 I ether5 PUBLIC<—>LOCAL 0x80 10 none
4 I ether6 PUBLIC<—>LOCAL 0x80 10 none
5 I ether7 PUBLIC<—>LOCAL 0x80 10 none
6 I wlan1 PUBLIC<—>LOCAL 0x80 10 none
7 I wlan2 PUBLIC<—>LOCAL 0x80 10 none
IP Adresses
0 address=192.168.88.1/24 network=192.168.88.0 interface=etherPOE
actual-interface=etherPOE
1 address=192.168.2.1/24 network=192.168.2.0 interface=PUBLIC<—>LOCAL
actual-interface=PUBLIC<—>LOCAL
2 D address=192.168.1.32/24 network=192.168.1.0 interface=WAN1
actual-interface=WAN1
I dont know why , but it seems to seperate it here, leaving a Gap. So ill attach some screenshots Below
configuration
0 ;;; DSL2
chain=prerouting action=mark-routing new-routing-mark=DSL2 passthrough=yes
1 ;;; DSL1
chain=prerouting action=mark-routing new-routing-mark=DSL1 passthrough=yes
I’m looking forward to hear from you, Arlic
