24hs routeros license expiration
after 24hs the router stops working because of license expiration… after that, am i able to login in order to enter a valid license?
I don’t think so…
But the 24 hours are actual uptime, i.e. if you shut your system down, the countdown stops :wink:
Best regards,
Christian Meis
ok… i shut it down until i pay …
cmit is right,
after demo licence time expires only available option is to reinstall ROS, all configuration everything is lost.
no, just demo you will do this methode.
if, you are not ready to buy new key for now, you can continue with ‘demo key’, just login to account server at mikrotik.com and make demo key, that server will send mail you ‘demo key’, than paste it into routerOS. i think you will access to your router is not 24hours.
keep it your software ID
Hasbullah.com
