2isp 1 RB751
Hi guys, if you had 2 internet connections by ethernet port (one with static public ips and the other with one public ip from dhcp) and one RB751U what would you do?
I want to use some devices with one isp and some with the other, and be able to fast switch from one to the other if one connection drops.
Thanks! :slight_smile:
Google PCC load balancing. Will actually make use of both connections and if one drop just us the one connection.
