3.0rc2 Wireless bug
Atheros Senao NMP-8602-ETSI 100mw (Atheros 5006X): 5ghz not work only 2.4 but sometimes random frozen communication between MT & Realtek CPE(only 802.11g) Scan or disable-enable interface on MTfix it.
Sparklan WMIA-165g (Atheros AR2413):sometimes random frozen communication between MT & Realtek CPE(only 802.11g) Scan or disable-enable interface on MT fix it.
3.0rc1 almost work fine: very rare frozen communication.
for me i have RB333
i have problems with compression and nstreme with rc2
didnt try the the rc1
Just thhis weekend I seen teh same problem with 2.9
Will work but then disconeect and bounce in and out of connection
I turned compression off and it worked
could you please tell what version of the software you are running and experiencing problem with compression/nstreme?
please make the support output file when it doesn’t work and send it to support@mikrotik.com
the problem fixed
rc3
but i still getting low throw but compare to rb133
please provide more info on your low throughput tests.
