3.14 upgrade bad on X86!!! causes CPU peg
The 3.14 x86 upgrade causes a CPU peg on several of my machines. The only way to get at the machine is to unplug the connection(s) providing routing updates, ftp on older version (3.13 workes for me) and reboot.
I suspect routing package, perhaps BGP.
Am running BGP and OSPF
I have benn able to confirm that the BGP module on 3.14 (and for that matter 3.14RC1) cause the CPU to peg on an x86. It works fine on 3.13.
Tech support advises to use routing-test for BGP if running 3.14
Cheers
Joe
OSPF seems to peg CPU as well, just not as fast.
Will try routing-test later tonight
3.14 on a 532A using routing-test package w/ ospf also pegs CPU at 100%
So it appears that its not just on a X86
