3011 update
hello,
I was screamed that I did not update the 3011, ok so I have downloaded from https://mikrotik.com/download routeros-mipsbe-6.43.4.npk uploaded to the file list - rebooted and …
same software - what I am doing wrong? I have downloaded the main package
https://www.youtube.com/watch?v=oMJYENGOauM what I have been followed
did auto update when connecting to the internet and works
To answer your question, 3011 is an ARM based device so the mipsbe file would not be helpful.
When logging in (via winbox at least) it will tell you the architecture in the title of the window in brackets (arm), (mipsbe), (tile) etc.
I see so I have been using the wrong file for uprade ehhhhhhhh ok I will check the architecture and let you know
It’s ARM like the poster above has said.
You can do > System>Packages>> Check For Updates >> Download and install >> Reboot system is updated
thank you all, all I neede its ARM architecture so I know what download for. Thanks
Why could you not use the automatic update that ArchilMindiashvili describe above?
I can’t speak for OP, but there’s a legitimate case: when a router doesn’t have internet access (for any particular reason), user has to upload upgrade package(s) manually.
Although I don’t know if file uploading works when router doesn’t have IP address configured and management is done using winbox via MAC connectivity.
Yes it is possible to upload a file using mac-winbox and also with ro-mon
Enviado desde mi Redmi 3 mediante Tapatalk
Now I need to downgrade Ruteros and no luck - UPLOAD disconnects WInbox all the time - is it a bug ?
