Hi, was after a little bit of help please. Im in the process of moving to a new internet provider with my Mikrotik, both providers are part of the Australian NBN Network. My current provider uses a PPPoe client with login credentials as the underlying connection. As soon as the PPPoe client is activated, it connects instantly, receives a DHCP IP address,etc.
When i try and connect to the new NBN Provider, again with a PPPoe client on the Mikrotik, this time however the new provider doesnt require any authentication, just a simple PPPOe client. The client sits in “connecting” mode and never reports the PPP session as established/connected. Interestingly though i can pass traffic over the link whilst the client is “Connecting”. However looking in the logs, i can see the PPPoe client constantly (ie once a minute, maybe more) disconnecting and reconnecting continuously.
I’m not really sure whats causing this issue and at a loss of how to stop it. Appreciate if anyone can provide some feedback please.
Also Aus, NBN provider to be exact. NBN is L2 network - RSP has choice of PPPoE, IPoE or any other ‘auth’ method.
If your provider says you dont need authentication, then they are likely using IPoE. On your device, this means a DHCP Client (ip → DHCP Client) added to the WAN interface. DHCP client options include adding default route and peer DNS etc. This is likely why your traffic is actually working, default config probably has a DHCP client running on your WAN interface, and your PPPoE interface constantly failing has no bearing on anything else other than filling up your log and sending unanswered PADI’s into the network.
Try disabling the PPPoE interface, if it still works then your good to go.
Disable your PPPoE interface and put a DHCP client on the ethernet interface you are using for the NBN. Some modem/routers - like the Telstra ones - will automatically try PPPoE (given you have put your PPP login in) and DHCP/IPoE until something works but they have to work on ADSL and NBN lines. If you aren’t sure ask your ISP what they use.
