/ip route pr detail
1 S dst-address=0.0.0.0/0 gateway=x.x.x.30
gateway-status=x.x.x.30 unreachable distance=11 scope=30 target-scope=10
I also read that it wasn’t supported, but I also read multiple times, that it can be made to work with an IP of /32, but this hasn’t worked for me either.
I spent a few minutes testing. Unfortunately my tests did not result in connectivity either.
First I tried my Windows PC. It didn’t like a /31 at all and wouldn’t let me use it.
Then I used a Cisco router and Mikrotik on the same LAN network. I added 10.99.99.0/31 on the Cisco, and 10.99.99.1/31 on the MT. The MAC addresses do indeed show up in the ARP table. However the packet sniffer on the MT never showed my pings arriving. Unfortunately that’s all the time I have right now.
It may have already been suggested, but you might try a /30 on the Mikrotik.
I was trying to turn up a /31 BGP network for up-stream peering and it flat-out did not work no matter what I tried.
However , my Cisco router did support a /31 doing BGP.
To make my Mikrotik work , I ended up using 4-IPs (aka /30) on the BGP-WAN because for some reason a Mikrotik using 2-IPs (aka /31) on on a BGP-WAN would not work.
So , with the limited number of IP V4 addresses available , having to burn up 4-IPs on /30 interfaces instead of 2-IPs on a /31 interfaces is a huge waste of IPs , especially when you have hundreds of /30 networks that could be twice as many /31 networks.
Re: “… I have been able to get it to work with a /32 …” , not sure I undersdand:
/30 = 4 IP v4 IP addresses
/31 = 2 IP v4 IP addresses
/32 = 1 IP v4 IP address
In my past , a /30 (4 IPs) has always been used for ISP router to Customer router , where the 4 IPs are used for (#1 - Network IP , #2 - ISP router IP , #3 - Customer router IP , #4 - Broadcast IP) - ((( and/or a /30 is often used when routing 4 IPs )))
In my limited experience , a /31 (2 IPs) has always been used for ISP router to Customer router , where 2 IPs are used (#1 ISP router IP , #2 - Customer router IP – where there really is no Network or Broadcast IP address). ((( and/or a /31 is often used when routing 2 IPs )))
And yes - I know that ISP layer 3 network hand-offs to customer routers can also use /29s and /28s and larger IP blocks.
However , I do now know how to do a layer 3 hand-off from an ISP router to a customer router using a /32 (only a single IP). ???
Of note - I kinda remember 20 years ago there was a Cisco way to do a NO-IP address route from an ISP router to a customer router. I’ve forgotten how it worked but I think it was more like MAC/ARP communications where routes were just sent to an Interface and not to a specific IP router address.
So on to my question for you re “In testing, I have been able to get it to work with a /32 if I’m going Mikrotik to Mikrotik”. Are you trying to route a /32 (single IP v4 address) between routers -or- are you trying to make layer 3 network between two routers using a /32 on the router WAN-2-WAN network -or- are you trying to make a VPN (VPN-Tunnel / EoIP / private IP tunnel ) configuration which uses use a /32 IP address (from your ISP) and aside from the VPN configuration the router network is already built and running between you and your ISP ?
A /32 IP v4 address can be used as a loop-back IP address (an interface that does not directly talk to anything - the IP block is a single IP address)
If a /32 IP v4 address is used on an ethernet interface then that IP address will not directly talk to anything - the IP block is a single IP address)
In both cases above , you can remotely ping the /32 IP v4 address and telnet/ssh/http/winbox/ftp to the single IP v4 address but that /32 IPv4 address is a single IP address and not part of any network. (Example , you do not route through that interface with the /32 IP v4 address to another router)
However , there is something you can also do , a secondary IP address on an interface (loop-back or ethernet or any other interface). Example , let say router1-ethernet1 is 192.168.0.1/30 and it is connected to router2-ethernet2 and it is 192.168.0.2/30. The two routers can route to each other and ping each other. Now it is possible to also do this … On router1-ethernet1 you can add a second IP address of 10.0.0.1/32 -and- on router2-ethernet you can add a second IP address of 172.16.0.1/23 , and you have routes for both of the two /32 IP address on each router so that they know where to route to get to the other /32 IP address , then both routers can ping the other routers /32 IP v4 address using the /30 network and routes between the routers.
With what you are describing:
R1: Ether1 IP address: x.x.x.31/32; Network: x.x.x.30; Gateway: x.x.x.30
R2: Ether1 IP address: x.x.x.30/32; Network: x.x.x.31
I think a Cisco router can do something more like this (using a /31 network between the two routers) (this is assumming both router Ether1 interfaces are connected together):
R1: Ether1 IP address: x.x.x.31/31; Network: x.x.x.30; Gateway: x.x.x.30
R2: Ether1 IP address: x.x.x.30/31; Network: x.x.x.31
I think /31 might be supported for cisco devices. Anyways
considering your example " ISP of x.x.x.31/31 with a gateway of x.x.x.30"
-i would try extending the subnet for those two ips to fit inside (and not to fall in broadcast one) to /26 → 255.255.255.192
-assign the router the ip x.x.x.31/26
-and configure 0.0.0.0/0.0.0.0 to x.x.x.30
