Here is my problem, Tried upgrading 433ah to 3.30 but on reboot could not login with winbox, No mac address / no ip address
I can gain access by hyperterminal with serial cable, but i get “Kernel not found”
I did not assign a IP address to the 433, so i am unable to connect via netinstall net booting as i cannot tell netinstall the client ip address is, as it does not exist?
when i change boot “boot device” on the 433, ( catch21 )
I can upgrade the firmware on the 433, which not what i want to do but reinstall the OS.
If i can assign an ip to the 433 then i can use netinstall, I was looking at the boot protocol
of bootp, or dhcp, could i assign a ip by dhcp
At present when i boot 433 and using hyperterminal i get “please, check ethernet cable … Ethernet link absent.. trying bootp protcol …failed kernel loading failed”
Any help please,
n21roadie
