I was wondering if there are any supported 4g USB modems for the Routerboard out there. In particular I’d prefer an LTE Modem from Verizon, but I would settle for a 4G USB modem from Sprint.
I looked over the list of modems and it looks like its just a list of 3g Modems.
I’m testing out a few modems now and it’s not looking great. I have the Pantech UML 290 for Verizon LTE and the U301 for Sprint. But I get no where when I try to follow these instructions:
But after implementing this and starting the ppp-client I get the following errors:
02:19:56 system,info device changed by admin
02:20:01 async,ppp,info ppp-out1: initializing...
02:20:01 async,ppp,info ppp-out1: reseting link...
02:20:01 async,ppp,info ppp-out1: reseting link... - could not acquire serial port
02:20:01 async,ppp,info ppp-out1: disconnected
02:20:03 async,ppp,info ppp-out2: initializing...
02:20:03 async,ppp,info ppp-out2: reseting link...
02:20:03 system,info device changed by admin
02:20:11 async,ppp,info ppp-out1: initializing...
02:20:11 async,ppp,info ppp-out1: reseting link...
02:20:11 async,ppp,info ppp-out1: reseting link... - could not acquire serial port
02:20:11 async,ppp,info ppp-out1: disconnected
02:20:21 async,ppp,info ppp-out1: initializing...
02:20:21 async,ppp,info ppp-out1: reseting link...
02:20:21 async,ppp,info ppp-out1: reseting link... - could not acquire serial port
02:20:21 async,ppp,info ppp-out1: disconnected
[admin@MikroTik] /interface ppp-client>
I’m done with my testing at this point. I mailed in my supout to technical support in the hopes that they can get it to work. No matter what channel I try on the port I can’t get the modem to respond.
I had quite a few problems also with supported 3G modems, the problem is becouse they have also drive with SW in them, switching the USB stick to modem only mode, and modems are working fine. Check on www for AT command for particular modem, how to switch it to modem only mode.
