I have recently figured out how to connect a Pantech UML290 to the Verizon LTE network here. My problem is that every so often the connection drops and I’m stuck here in my log:
00:47:30 system,info,account user admin logged in from 192.168.88.100 via ssh
01:21:27 async,ppp,info ppp-out1: terminating...
01:21:27 async,ppp,info ppp-out1: disconnected
01:21:37 async,ppp,info ppp-out1: initializing...
01:21:37 async,ppp,info ppp-out1: reseting link...
01:21:38 async,ppp,info ppp-out1: terminating... - modem hunged up
01:21:38 async,ppp,info ppp-out1: disconnected
01:21:48 async,ppp,info ppp-out1: initializing...
01:21:48 async,ppp,info ppp-out1: reseting link...
01:21:49 async,ppp,info ppp-out1: initializing modem...
01:21:49 async,ppp,info ppp-out1: dialing out...
01:21:52 async,ppp,info ppp-out1: authenticated
01:21:52 async,ppp,info ppp-out1: connected
01:21:52 system,info dns changed
01:22:24 async,ppp,info ppp-out1: terminating...
01:22:24 async,ppp,info ppp-out1: disconnected
01:22:24 async,ppp,info ppp-out1: initializing...
01:22:24 async,ppp,info ppp-out1: reseting link...
I have the keep-alive setting enabled, but it doesn’t seem to work:
[admin@MikroTik] /interface ppp-client> print
0 name="ppp-out1" max-mtu=1500 max-mru=1500 mrru=disabled port=usb4
data-channel=0 info-channel=0 pin="" user="7048137024@vzw4g.com"
password="vzw" profile=default phone="*99***3#" dial-command="ATDT"
modem-init="ATZ;ATQ0 v1 E1 S0=0 &C1 &D2 +FCLASS=0" null-modem=no
dial-on-demand=no add-default-route=yes use-peer-dns=yes
keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
Does anyone have any ideas on how I can fix this?
Thanks,
Charlie
