I bought a pair of cAP ax’s. They are both configured identically, but I noticed that nothing connects to the 5G radio on one of them. I looked in the log to see if there was anything. It shows all clients connecting to wifi2.
So far, it’s a bare-bones config:
[admin@cAPax01] > export
# 2023-11-03 12:16:55 by RouterOS 7.11.2
# software id = WU0A-I8IJ
# model = cAPGi-5HaxD2HaxD
# serial number = HEG08MMG27J
add name=bridge1
/interface wifiwave2
set [ find default-name=wifi1 ] configuration.country="United States" .ssid=\
JPJPOH disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] configuration.country="United States" .ssid=\
add bridge=bridge1 interface=all
/ip dhcp-client
add interface=bridge1
/system clock
set time-zone-name=America/New_York
/system identity
set name=cAPax01
/system note
set show-at-login=no
[admin@cAPax01] >
5620 looked quiet, so I went with that. I’m not sure I set all the options correctly:
# 2023-11-03 14:38:29 by RouterOS 7.11.2
add name=bridge1
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency=5620 .width=20/40/80mhz \
configuration.country="United States" .manager=local .mode=ap .ssid=JPJPOH disabled=no \
set [ find default-name=wifi2 ] configuration.country="United States" .ssid=JPJPOH disabled=no \
/ip dhcp-client
/system clock
/system identity
set name=cAPax01
/system note
It looks like the radio has turned according to the Android Wifi Analyzer app, but no clients are switching from 2.4 automatically. I’m going to try to restart them close to the AP and see what happens.
Clients are connecting to 5G when they start the connection near the AP. If they connect at further distances, they don’t switch from 2G to 5G when they get close to the AP.
Is that normal? Am I missing a setting? These are new APs and I’m trying to figure out how to set up CAPsMAN2.
This behaviour very much depends on clients (and almost doesn’t depend on AP).
The wifiwave2 driver enables the roaming features (802.11 r/k/v) … I guess they are on by default now. These help to improve client roaming … but it’s again up to client who has to support those extensions. Some vendors develooed some tricks to force (legacy) clients to certain band/AP, MT doesn’t implement any.
