6.30rc17 on CCR1016 multiple special dummy rules
Okay seems now I have 3 example rules and growing :frowning:
So how can you remove duplicates - all I get is unable to remove inbuilt rule. That’s fine but 3 of them?
0 D ;;; special dummy rule to show fasttrack counters
chain=prerouting
1 D ;;; special dummy rule to show fasttrack counters
chain=forward
2 D ;;; special dummy rule to show fasttrack counters
chain=postrouting
Only affects CCR, I have many MT 951Gs and two CRS switches
Ticket # 2015061266000075
You can fasttrack only forward traffic, there are 4 places in firewall where you work with forward traffic
a) filter forward
b) mangle prerouting
c) mangle forward
d) mangle postrouting
In each of this places you need to inform the user that fasttrack is enabled and some traffic will not be accessible for his setup.
And it is all the same for all arhitectures, i’m looking right now on the same rules on mipsbe
Yes I understand about fasttrack - but in this case No that’s not correct, in 6.30 they have added this embedded rule it just shows fastrack ‘possibility’ and its not editable, removable, disable, etc.
Its a bug only for CCR as its not checking to see the rules already there its just adding another rather than checking its there before adding another. Not even the comment can be edited.
The rules physically embedded in the firmware.
Its a bad bug as I just upgraded to rc19 and it hosed the CCR. I had to ethernet boot it and recover.
It was complaining in the console over serial that the entire OS is read only
No doubt by the ever increasing read only example rule..
I’ll await for this to be mentioned as fixed in the RC changelog
Vote against dummy rules in firewall: http://forum.mikrotik.com/t/feature-request-remove-fasttrack-dummy-rule/89511/1
