Remember to make backup/export files before an upgrade and save them on another storage device;
Make sure the device will not lose power during upgrade process;
Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.49.23 (2026-10-07):
system - improve stability (includes CVE-2026-84411);
To upgrade, click Check For Updates under System/Packages menu and select the long term Channel in RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
Everything went smoothly
I encountered an issue after the update (please post about the device, configuration, and unexpected symptoms)
I encountered an issue, but solved it (please post the solution)
0voters
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. The file must be generated while a router is not working as suspected or after some problem has appeared on the device
I’ve updated around a hundred devices across dozens of different types: no issues.
So far, I’ve only updated one CHR from 7.23.7 to 7.23.8: everything is fine for now.
I’ll post a full report in the 7.23.8 thread later when I upgrade also the other 4/5 devices with 7.23.7.
Why is 6.49.23 release name 6.49.23 (stable) and not 6.49.23 (long-term)? 6.49.22 was released with release name 6.49.22 (long-term). If you're gonna include the branch in the name, at least apply it consistently.
Wow, thanks for the enlightenment! However, the question was for @rextended to share details about their massive deployment, not for a random lesson on what an ISP is.
There's no need for the sarcasm.
As has been pointed out, I am a (W)ISP & (F)ISP.
MikroTik products handle everything, from the network Edge to the AP inside the customer's premises
(whether it’s a business or a private individual, ultimately, only the number of devices changes).
As for CPEs, I have stopped adding more MikroTik units because, quite simply,
MikroTik has completely abandoned the WISP market (there’s not much more to say on that).
I have also moved on to other systems (only for Wireless CPE), though I won’t be advertising which ones.
The existing base of MikroTik CPEs remains, but for new customers,
I exclusively use Wireless CPEs from other manufacturers,
companies that aren’t stuck in the past, and for whom proprietary drivers are a key selling point.
But on the inside, after the wireless link, there’s always a MikroTik device acting as the Router.
It’s in a league of its own, there’s simply no comparison.
No point in beating around the bush.
Version 6 is rock-solid, while version 7 is still full of bugs;
but the junk that other manufacturers churn out is just abysmal...
I make my living from this work, and I also find it enjoyable, so I don’t want any bullshit:
I use MikroTik products because they’re the only ones that let me sleep at night.
I'll try to remember that next time my network goes down. Have a good one!
Thanks for the reply, really interesting setup!
I have a similar experience, just on a much smaller scale. I used MikroTik for a long time, but their WiFi fell so far behind that I moved to Ubiquiti a while ago.
My edge router was always a MikroTik board or x86 with RouterOS. But just like you mentioned about v7 bugs, I ran into issues I simply didn't have the time to troubleshoot, so I switched to a Debian router. Can't complain so far.
I still have a few of their devices in my network, so we haven't parted ways completely.
