When you export file on the master/ap, the export doesn’t contain the SSID but it does contain the reset including the frequency and password, when you export file on the slave/stations it contains the SSID. You can manually enter the SSID into the exported file for the AP and load that without errors and it works.
thank You for reporting this, we will look into it.
