7.16 DHCP Issues
I have various systems using RB5009 and CCR Routers and CAP AX access points throughout. I have the CAP AX on DHCP Clients and everything was working fine from 7.15.3 and prior. I upgrade the routers to 7.16/7.16.1 and everything still works fine, but once I upgrade the CAP AX to 7.16/7.16.1, there is an issue with the DHCP clients. The CAP AX gets assigned an ip address from the router and then 10 seconds later, it disconnects, and then gets reconnected. Looking at the DHCP leases tab in the router, it keeps assigning an IP. and then 10 seconds later it disappears, and then re-assigns it. It keeps doing this over and over. I have been forced to downgrade the CAP AXs down to 7.15.3 until I can resolve this issue. Any help?
Thanks in advanced!
Can you share the configs:
/export file=anynameyoulike
Remove serial and any other private info, post between code tags by usnig the </> button.
Let me pull the file next time I am at a clients place with the issue. Right now, I have all routers running 7.15.3 to avoid this issue.
Until then though, why would a package upgrade to 7.16 affect the DHCP issues with my CAPs when it was working fine with 7.15.3?
