Hi
I am chasing down an issue which causes the DNS resolver process of some SIP devices to crash. I narrowed it down to the crash happening when the DNS Service on a Mikrotik is queried and finally managed to trace a DNS query - and especially the reply which caused the resolver on this specific patton SIP gateway with latest firmware to crash.
I suspect the Microtik DNS does not return a correct reply.
Frame 139: 147 bytes on wire (1176 bits), 147 bytes captured (1176 bits)
Ethernet II, Src: PattonEl_0d:ae:f0 (00:a0:ba:0d:ae:f0), Dst: Routerbo_76:78:d0 (cc:2d:e0:76:78:d0)
Internet Protocol Version 4, Src: 172.29.255.10, Dst: 192.168.57.1
User Datagram Protocol, Src Port: 64306 (64306), Dst Port: domain (53)
Domain Name System (query)
Transaction ID: 0xf163
Flags: 0x0100 Standard query
Questions: 1
Answer RRs: 0
Authority RRs: 0
Additional RRs: 0
Queries
_sip._udp.dev-cpereg.devtel.imp.ch: type SRV, class IN
[Response In: 142]
Frame 142: 626 bytes on wire (5008 bits), 626 bytes captured (5008 bits)
Ethernet II, Src: Routerbo_76:78:d0 (cc:2d:e0:76:78:d0), Dst: PattonEl_0d:ae:f0 (00:a0:ba:0d:ae:f0)
Internet Protocol Version 4, Src: 192.168.57.1, Dst: 172.29.255.10
User Datagram Protocol, Src Port: domain (53), Dst Port: 64306 (64306)
Domain Name System (response)
Flags: 0x8180 Standard query response, No error
Questions: 1
Answer RRs: 2
Authority RRs: 13
Additional RRs: 13
Queries
Answers
_sip._udp.dev-cpereg.devtel.imp.ch: type SRV, class IN, priority 0, weight 0, port 5060, target dev-sbc01.devtel.imp.ch
_sip._udp.dev-cpereg.devtel.imp.ch: type SRV, class IN, priority 0, weight 0, port 5060, target dev-sbc02.devtel.imp.ch
Authoritative nameservers
<Root>: type NS, class IN, ns i.root-servers.net
<Root>: type NS, class IN, ns k.root-servers.net
<Root>: type NS, class IN, ns m.root-servers.net
<Root>: type NS, class IN, ns f.root-servers.net
<Root>: type NS, class IN, ns a.root-servers.net
<Root>: type NS, class IN, ns g.root-servers.net
<Root>: type NS, class IN, ns l.root-servers.net
<Root>: type NS, class IN, ns b.root-servers.net
<Root>: type NS, class IN, ns e.root-servers.net
<Root>: type NS, class IN, ns d.root-servers.net
<Root>: type NS, class IN, ns c.root-servers.net
<Root>: type NS, class IN, ns h.root-servers.net
<Root>: type NS, class IN, ns j.root-servers.net
Additional records
i.root-servers.net: type A, class IN, addr 192.36.148.17
k.root-servers.net: type A, class IN, addr 193.0.14.129
m.root-servers.net: type A, class IN, addr 202.12.27.33
f.root-servers.net: type A, class IN, addr 192.5.5.241
a.root-servers.net: type A, class IN, addr 198.41.0.4
g.root-servers.net: type A, class IN, addr 192.112.36.4
l.root-servers.net: type A, class IN, addr 199.7.83.42
b.root-servers.net: type A, class IN, addr 170.247.170.2
e.root-servers.net: type A, class IN, addr 192.203.230.10
d.root-servers.net: type A, class IN, addr 199.7.91.13
c.root-servers.net: type A, class IN, addr 192.33.4.12
h.root-servers.net: type A, class IN, addr 198.97.190.53
j.root-servers.net: type A, class IN, addr 192.58.128.30
[Request In: 139]
Why the heck, is the Microtik DNS sending back all the authoritative DNS Servers as additional RR? There is no reason to do so, probably this is more then the allocated DNS reply memory of very simple resolver like in SIP phones can handle and cause them to crash.
When using BIND as a DNS server, I could not reproduce the issue.
-Benoît-
