Type in a change in the interface name (e.g. ether1-test)
Press Apply
Web UI goes in to refresh/reload loop
Jump to Web UI terminal to see the bug effect clearly
After that you can see that everything just repeatedly reloads/refreshes preventing any modifications to UI and reverting any typed text on fields and in terminal.
I’ve tested this with ROS 7.20 on multiple platforms (CHR, various hardware) and with Chrome, Safari, Brave, Firefox browsers. Only common thing I’ve found in devices expericieng this issue the ROS v7.20.
So far I’ve been able to complete the required configuration changes using CLI, but this is really annoying.
Move back to 7.19.6 perhaps if it annoys you that much ?
Did you see this as well in beta/rc versions ? Or didn't you even look at those versions ?
Why did you move to 7.20 to begin with ? If you had followed the release thread for that version, you would have known already by now there is more then 1 thing not "on par" with that version.
Best to sit it out until the wrinkles have been ironed out.
Generally (especially for production or when you can not accept downtime) it's not a bad idea to wait at least for .1 or .2 version.
Or accept the bugs
At home I follow most beta/rc versions, for production however I am a lot more cautious.
