7.22 Ping interface option missing
Interface option not showing on 7.22
user not reading forum before asking questions…
How many more times do you have to rewrite it?
Suffice just read the replies already present in the various topics where you posted the same thing.
Bring back the dropdown menus!!
boo mikrotik
Certain choices just... ARE NOT UNDERSTOOD...
Not defending searching forum laziness, but MT ping help should be more clear about <dst>[%if][@vrf] format, %if is mentioned only for MAC ping example (which can confuse certain users that is related only to MAC ping) and ability to choose which routing table to use with @vrf is not even mentioned and in VRF help is old ping syntax example.
Are you implying that surprisingly Mikrotik help is not updated with the changes in the current (or last few) releases? :astonished_face:
Regular forum readers are probably not surprised, but for others updated help will cetenally help to avoid creating topics like this, ofc. there will be always lazy/least effort approach users but there is nothing to do about that except silence/ignore…
Just one of the many topics which are one step forward, three steps back.
For a ping, they want you to be a PhD:
grafik
If I want to ping 10.10.0.1 through VLAN111-Interface do I have to:
<<10.10.0.1>[%VLAN111]><VLAN111>
<<10.10.0.1>><VLAN111>
@MatiasMK88
Is there any logic to the thumbs down?
Is it correct for you that they removed the drop-down menu and forced the use of % and @???
So, if you understand the logic behind this idea of ​​removing items and not even providing instructions,
please enlighten us instead of remaining in the shadows.
10.10.0.1%VLAN111
It's kind of pseudo regex syntax:
| means OR, [x] means optional and <x> is a placeholder for a value
Works for folks with some SW background, but is a weird choice for UI user guidance
And the << at the beginning seems to be wrong and should be <
Yeah, that's somewhat similar to what command line programs since decades use to document their parameters. Usually, they use BNF or EBNF notations. You'll see that in man-pages as well, example:
https://www.man7.org/linux/man-pages/man8/ip-route.8.html
The syntax shown by the RouterOS CLI is closer to the BNF notation
I like it for the CLI, preferable with some smart tab completion. But Winbox and Webfig GUI should probably come up with something Graphical...
Yes, as I wrote elsewhere, they should introduce a new field type in WinBox4 for “address with optional interface and VRF” and have it behave in an intelligent way. Probably it would be displayed as 3 sub-fields, much like it was before (a space for the address and two drop-down select lists for interface and VRF, the latter would only be shown when VRF has been configured).
The opportunity is also there to solve the ambiguity of DNS resolving. When typing a DNS name there would be some way to do an immediate “lookup” (with optional force to IPv4 or IPv6) and the name would be replaced by the address while still in the field, or when this is not done the name would be sent to the router to be resolved there. Because DNS resolution on the system running WinBox can be different from when done on the router.
There is already support for the address%interface field type, here are some screenshots from an older post:
That's even an array of address%interface items. Now they need a 3rd dropdown for address%interface@vrf.
And to complete the collection: Webfig shows a %sign, but no dropdown for the interface
I think it all started here: WinBox v4.0.1 released! - #109 by MatiasMK88
