7.23.6 [long-term] is released!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.23.6 (2026-09-14):
  • bgp - improve stability;
  • certificate - add "SSL. com Root Certification Authority ECC" to built-in root certificate authorities store;
  • certificate - allow importing a cross-signed certificate without replacing the existing one;
  • certificate - refactor certificate internal processes;
  • certificate - remove "GoDaddy Class 2 CA" from built-in root certificate authorities store;
  • console - improve stability;
  • crypto - improve stability (CVE-2026-67278);
  • ipsec - fix duplicate connections on IKEv2 retransmissions;
  • ipsec - improve stability;
  • leds - fix LEDs set to interface status staying off when the interface is active;
  • ppp - improve stability;
  • ptp - add manual configuration of PTP message intervals and per-port enabling and disabling;
  • ptp - fix PTP offset instability under heavy background multicast traffic;
  • ptp - fix PTP timestamps showing the wrong time on CRS510;
  • sfp - improve QSFP-DD breakout link establishing to NVIDIA DGX Spark and other devices;
  • system - improve stability;
  • user - improve failed login delay logic (CVE-2026-16347);
  • wifi - update radio regulatory information;
  • www - improve stability;
To upgrade, click Check For Updates under System/Packages menu and select the long term Channel in RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
  • Everything went smoothly
  • I encountered an issue after the update (please post about the device, configuration, and unexpected symptoms)
  • I encountered an issue, but solved it (please post the solution)
0 voters
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. The file must be generated while a router is not working as suspected or after some problem has appeared on the device
You guys understand what LTS is right?! Right?! I haven't even gotten 7.23.5 fully deployed.
As of now, there is no formal statement regarding CVE-2026-16347 or CVE-2026-67278 at https://mikrotik.com/supportsec.
The only entry there is the post from September 3, 2026, which lists CVE-2026-67277, CVE-2026-86060, and CVE-2026-67276.
You don't like updates?
If they don't mention the CVE, it's not ok.
Now they do, still not ok.
Make up your mind please.
I prefer the fix is out before it is known there is an issue for such things.
My same point of view
Loaded to 3x CAP-ax via CapsMan, hAP-ax2, RB5009, and 2x CRS305 without incident.
(hAP-ac2 pending update)
hAP-ac2 with wifi-qcom-ac also updated without incident.
No issues seen of any kind coming from 7.23.5!
Thankyou
Edit:
Quad9 still awful not usable.
 DOH MONITOR | 16:13:36 | RUNTIME: 8 min | CYCLE: 99/∞
Target         Type  MS  Max Med Jit Fail Att  %    Status  Last Err  SF  TO
Quad9  DoH2    Cold  122 593 119 3   2    99   97%  OK      TIMEOUT   1   1
Quad9  DoH2    Warm  2   221 3   1   0    99   100% OK      NONE      0   0
Cloudflare seems fair enough for me
 DOH MONITOR | 16:24:45 | RUNTIME: 8 min | CYCLE: 99/∞
Cloud  DoH2    Cold  25  87  32  7   0    99   100% OK      NONE      0   0
Cloud  DoH2    Warm  29  29  2   27  0    99   100% OK      NONE      0   0
I like that they named the CVE's, Kudos to mikrotik for a step in the right direction. +1, :heart:
This helps cut the noise and anxiety when inevitably some critical CVE hits
The fact that this specific CVE is still under embargo makes no difference to me as a user of their software.
And in my view, is generally good practice from the researcher.
It means that they properly communicated with MikroTik before publicizing their work.
So.. just a direct effect of good work by the researchers, and good communication and documentation practices from Mikrotik.
In this scenario the /supportsec blog is a redundancy, because all relevant info (update now, question us later) is already published in the changelogs.
Still, a lot of "improved stability" entries.... but we'll get there when we get there
The referenced CVE is neither new or under embargo, it's just not very interesting and so no one is really tracking or updating it.
The vulnerability is that if the api endpoint is exposed to the attacker, then if additionally the attacker can guess a correct username and password then they can do bad things. Duh.
The "vulnerability" is that the login attempts are not or inconsistently restricted. (And it isn't clear at all how they should be restricted...)
If I am not mistaken, within the established procedures (and perhaps even formal rules—I am not familiar with the details), the vendor is required to maintain a centralized source of information regarding all security vulnerability issues.
Hi there, updating on CCR1072 from v7.23.5 to v7.23.6 results in fatal kernel error (& thus failed update).
So have not tried on ARM only the TILE. Please advise whether you encountered this in testing?
Tried re-downloading in case of bad download, but same result when re-attempting.
Thank you kindly for your assistance in advance! Eager for your help.
What would be the global preference - delayed release to make long-term "longer" or to provide actually important fixes to end-users ASAP? :slight_smile:
I think the only thing not done well was that a 7.21.6 version could also have been released as 7.21.5 + only the critical fixes.
This would have allowed everyone on the then current 7.21.5 lts to upgrade immediately with minimal risk of breakage, and only then upgrade to the new 7.23.x lts at their leisure.
I only propose this sort of treatment for truly critical fixes.
CVEs or other vulnerabilities?
"Instantly."
Okay, okay... It’s not that much of an exaggeration...
But certainly within less than two business days.
And fixes for CVEs released for the specific minor version currently used in the Long Term release.
None of that "bumping the Long Term version to match the Stable version just to avoid releasing a patch for the specific minor release used in the Long Term" nonsense.
(I am referring specifically to that wrong and deplorable move where the Long Term version was shifted from 7.21 to 7.23, thereby forcing a host of radical changes that had occurred between those two minor releases.)
I would suggest that the Long Term version be one or more minor versions behind the Stable version.
E.g., if Stable is currently at 7.24, Long Term should be 7.22 or earlier.
